Expected dyno numbers?
I didn't have time to run anything to compare that to.
I would think that it would show more with a 10.5:1 compression however.
As much as people won't like this, hydraulic roller cams are NOT the 'end all' if you are looking for power.
Solid mechcanical rollers still make the most power...
Solid cams are better but you sacrifice alot of driveability and parts life such as vlv train items, etc...
But yes it would net you more power!
The camshaft you have ground with 110* lobe sep would get you more power but not with that compression!
But on a lower compression engine the 114 will help you out and also if you use a power-adder!
That cam specifies no less than 10:1 in the comp cams lit i believe, 9.7 is close enough for it to work fine!
my last custom cam before changing to a s/c friendly one was on a 109 and ecm had no probs, it's not always about the number there, many factors such as how aggressive is the lobe profile can factor into such as well as the entire build, ect ect......
not really, it all depends on the intended use/design.........there are such cams as TLSR = TIGHT LASH SOLID ROLLER, which is running a hydraulic roller lifter on a solid profile, use the proper lifters and it'll run a long time, don't and it'll fly apart.........no pulling the lower, just maybe the upper to access valve covers and checking adjustment is done 1-2 times a year. You can run a solid on the street as well and it be totally streetable, it all depends on the lobe profile you do with....aggressive, vs moderate, vs lazy as I call it..lol Don't get caught up in lift and duration numbers and think those are the be all to end all in choosing a cam
There is a real easy to tell how aggressive any cam will act.
Look at the duration @ .050 and look at the 'advertised' duration.
See what the % is at .050 compared to the 'advertised' duration.
If you get a cam that more than about 80% at .050 to 'advertised', it will be very aggressive.
Solid lifters were standard stuff in all hi-performance ehgines from all the auto makers until the great EPA did them in.
Cars ran fine for a whole lot more than a 1000 miles before they had to have the valve lash set.
