95 gt engine stalls
95 gt engine stalls
I have a 95 GT, the only upgrade is H pipes.
When i go to stop at stop sing lights or any other reason the engine stalls but if I slow down slowly and let the RPMs go down slow it will not stall then.
Can anyone tell me what might be the cause?
If the car idles good and the only time it stalls is during a rapid deceleration , you could have a bad vss ( vehical speed sensor) The vss is located on the trans where the speedometer cable goes and helps keep engine rpm up during deceleration .
It could also be the baffle in your fuel tank that is supposed to keep fuel at the pump pick up during starting and stopping and cornering. do you notice it missing around corners or when taking off suddenly.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
