Cold Start problems!!!
Old May 21, 2014 | 02:05 AM
87droptop's Avatar
87droptop
Default Cold Start problems!!!
Good morning,
I am have a lil cold start problem with my 87 drop top. When i start my car it wont stay cranked. I have to give it a lil gas for about 15-30 sec in order for it to stay crank and idle. It only happen like this on a cold start from not starting it for 3 or more days.
87 drop top
longtube headers
msd
E303 cam
SR intake
70 mm throttlebody
Gt 40 heads
3 row alminum radiator
Old May 21, 2014 | 07:48 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Pull codes to see if you have a bad ECT sensor. This sensor is the one that tells the computer the temps of the coolant / engine so it knows how much fuel to give at cold start or hot.
Old May 21, 2014 | 09:49 AM
AMWill's Avatar
AMWill
Former Sponsor
How long have you had this symptom since you installed those mods? Was the cold start issue immediate after the mods? Also, what base ignition timing are you using?
I'd check your ECT sensor as well, as 88_oragepeelnotch mentioned.
Shane
Old Jun 12, 2014 | 10:39 AM
87droptop's Avatar
87droptop
Im not getting an error message or anything. the car just acts like a very old chevy and needs to be giving so gas for 30 secs or less
Old Jun 12, 2014 | 10:43 AM
87droptop's Avatar
87droptop
Originally Posted by 87droptop
Good morning,
87 drop top
longtube headers
msd
E303 cam
SR intake
70 mm throttlebody
Gt 40 heads
My check engine light isnt even coming on. Having to give it gas on the start up is point less if i have fuel injection. Might as well be carburated
Old Jun 12, 2014 | 04:14 PM
88 orangepeel notch
Did you pull the codes? Some codes won't throw the check engine light so it's important to see what the computer has stored in memory. All you need is a paper clip and a pen and paper.
Old Jun 12, 2014 | 04:24 PM
Js88lx's Avatar
Js88lx
My 89 had this problem. It would take for ever to turn on when cold but once warm it would start right up! I spent a few hundred bucks before I could determine that the distributer went bad! Good luck!
Old Jun 12, 2014 | 05:08 PM
dawson1112's Avatar
dawson1112
If this is a symptom that popped up shortly after your mods it is likely because it needs idled up just a touch more . A bit of advance on the dizzy or a base idle reset would probly take care of it. My fox idled about 800-850 rpm when hot, I tried to get it down to the 750 range and it did the same thing on cold start. E303 cam needs a little extra rpm when cold.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
drfister
May 3, 2018 10:38 PM
MXBT187
Aug 20, 2015 02:36 AM
HIS S-197
Aug 10, 2015 05:47 PM
