Oil Pressure Question
I've had my 95 GT convertible for a long time. I haven't driven it since 2011 (took it apart to paint, moved, etc) and now I'm about ready to get it back on the road. It starts and runs fine, but the oil pressure seems a little high. It is almost to the red mark on the gauge after running 10 minutes or so in my driveway. I think it was close to the "L" in the word normal when I last drove it 6 years ago, but I just don't remember for sure. Where seems normal to you guys for this 5.0? The car has 99,500 miles, by the way, and is 100% stock.
The signal is electric, not an actual gauge with fluid running to it. It could be wrong.
Reasons oil pressure can go up:
thicker weight oil
blockage ie..clogged oil passage
Edit: had oil filter, that would actually lower it
thicker weight oil
I replaced the oil and filter before I started to paint it in 2011. It has just been started and stopped, and just driven around my driveway maybe 30 miles since then. I guess to be safe I should just drain the oil and get a fresh filter. I don't want to take any chances with a good running motor!
