Possible rod knock
Old May 5, 2019 | 02:52 PM
Sn95cody's Avatar
Sn95cody
Default Possible rod knock
So I'm at a loss here... drag raced a guy and everything was fine. About an hour later something started knocking while under a load but no knock at idle or cruising slowly through town. Also started a really bad idle that shakes the whole car and the smell of gas that makes your eyes almost water. I keep thinking a rod knock but I've never had the other symptoms with it. Any ideas what it is?
Old May 6, 2019 | 11:56 AM
Buck Sergeant's Avatar
Buck Sergeant
Sn 95 cody, there might be multiple issues here. I would suggest not assuming anything before you change the spark plugs and check the spark plug wires. Yes, this sounds goofy, but you must first have a solid base. The fact that the idle changed, and you had a strong smell of gas, might be symptoms that will lead us to the problem. Post your results.
aimhigh10
15
Nov 30, 2008 12:20 PM
gyea
Nov 13, 2008 12:46 PM
gyea
Nov 11, 2008 02:15 AM
forreal
4 Cylinder NA and Turbo
Oct 15, 2006 11:28 PM
