Sponsored by:
Sponsored by:
15 GT Premium will not run
Old Feb 28, 2019 | 10:30 AM
Civiced77's Avatar
Civiced77
Default 15 GT Premium will not run
Hello all, I'm new to the forums, but am in dire need of any help possible. I've owned my 15 GT for about 2 years now and just recently decided to modify it. I recently did a gt350 intake swap, gt350 throttle body,c&l racer intake, 47# injectors, and long tube headers which are open. All this is supported by a BAMA tune. After getting everything installed and tune downloaded, first start threw a P068A code which I cleared after speaking to tech support at BAMA due to it being a non issue. The car will turn over and attempt to crank but will not stay running. I've double checked all wiring connections and fuses but am still having no luck with the problem. Short of sending it to Ford I'm lost. Any advice or suggestions would be greatly appreciated.
Old Feb 28, 2019 | 12:44 PM
Derf00's Avatar
Derf00
Gentleman's Relish
P068A is specifically a PCM/ECM failure or power/wire issue
OBD-II Code Hard or no start in cold weather is defined as a ECM/PCM Power Relay De-Energized Performance - Too Early
The PCM Power Relay supplies power to the engine control module (PCM). If the PCM detects a variance in voltage from the Power Relay, the PCM will set code P068A.
Powertrain Control Module (PCM) failure
Powertrain Control Module (PCM) power relay failure
Wiring issue
What made AM say it was "non issue"?
Double check all of your wiring connections, make sure nothing is kinked or bent weird, find the PCM relay and try swapping it with another one like the one from the AC temporarily to see if the problem is fixed.
Old Feb 28, 2019 | 01:00 PM
Civiced77's Avatar
Civiced77
Wiring issue
The code was considered a non issue because they said it's not uncommon for the code to appear after flashing a performance tune. Once I cleared the DTC it has not come back and I am not getting any other codes now. I swapped relays as you suggested and the car is still doing the same thing
Old Mar 1, 2019 | 12:50 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Well, only two reasons why a modern car won't start if it turns over. Spark and/or Fuel is not as expected. I wonder if the tune is properly set up for your mods...
Do you smell any fuel out the exhaust? Pull a plug or two after cranking and see if they are wet (fuel). That would indicate too much fuel being dumped into firing chamber. Basically flooding the engine.
Old Mar 2, 2019 | 06:12 PM
Civiced77's Avatar
Civiced77
Plugs aren't showing any excess fuel indicators, I also tried the cylinder clearing process (holding throttle to floor to cut injectors off), I can barely smell fuel but its not overwhelming and with open exhaust I'm curious if that's normal. Is it possible the open headers are an issue? All O2 sensors are installed and brand new
xkillerxnatedog
Oct 17, 2020 01:14 AM
Silvercracker99
Aug 24, 2018 10:26 AM
87Foxbody2.3L
4 Cylinder NA and Turbo
Aug 17, 2009 12:28 AM
95viperred
Feb 6, 2007 01:27 AM
jepostang
Jan 16, 2007 08:29 PM
