Problem with 5.0 Clutch / Slave Cylinder
I just hit 200 miles and i was starting to drive normal for the last 50 and the clutch was starting to feel stronger. I'm not saying there isn't an issue because it really does feel like it needs to be bled but you really think there would be air in brand new clutch system for everyone who order a manual?
I can consistantly pop 2nd and 3rd since 200 now.
So far I have not heard of any other car experiencing the "pedal stuck on floor" issue.
As I stated it used to be an issue with F-Bodies and Vettes during my LS1 days.
Im hoping my car is the only one with the issue as it should mean an easy fix.
You might just be talking about the typical soft feel from the hydraulics. My 2007 did feel a bit firmer though. Hopefully that means they have upgraded the Slave Cylinder.
Gene- Any update? We delivered our first manual trans '11 GT yesterday. The customer was heading back with some paperwork and the clutch fried, smoke everywhere.
As much as I hate waiting for my car, I hope it is right when it gets here.
I was out playing with it today to figure out how to replicate it for the dealer. So far no matter how hard I try I cant get it to do it. The clutch pedal also feels firmer (as noted by another poster above). I have no explanation for this.
Note Evolution torched their clutch in 12 passes. Of course a 10% increase in power, Taller than stock ET Drag Slicks, and very few break-in miles might not have helped. Mine hooks hard enough to break the tires loose on the 2-3 shift.
Think we should start campaingning for the recall to install the GT500 Dual Disc Clutch yet?
UPDATE:
https://mustangforums.com/forum/2005...ml#post7045374
5.0 clutch problem
Hi:
I am ready to buy a GT/CS sometime nextweek, but the clutch problem made me think twice now. Is this problem fairly common for 5.0 M6? Will I be able to find it out easily during the test drive? Should I wait for a GT/CS built after Agust 15 (Job 2)?
TIA
Joe
TIA
Joe
Gene,
It's not the slave that's causing your problem. It's the clutch pedal assembly.
https://mustangforums.com/forum/5-0l...issue-fix.html
I have had my 11 GT for about a month now and during all of my WOT "experiments" I haven't run across any of these clutch petal issues... I hope I don't cause I would hate to have to spend extra money on an already decently expensive car
Jared
