First look: 2011 5.0L Clutch Assembly & Shifter
We pulled our tranny today so we can start working with one of our vendors on aftermarket clutch options. Here's a few pics of what we found. We should have some great clutch options available for these cars real soon. I also believe we'll see a TSB about the clutch pedal box assembly which is supposedly the cause of the clutch pedal sticking to the floor during high rpm shifts.
In the meantime enjoy the pics and feel free to comment or ask questions if you have any.
Guess how many splines are on the new clutch assembly
Nodular Iron Flywheel
A billet spacers is used to shim the slave cylinder.
Check out this crazy shifter. I'm sure the aftermarket companies are going to have a blast trying to figure this one out.
I guess its a good thing that the stock shifter on the MT82 is already pretty good. I found it to be much better than my friend's stock '05 shifter.
Usually the person assembling the car will put a small dot on an area already completed. For instance, on the new electric power steering pump, there will be a dot of blue paint on each bolt once it's been torqued to spec. (May be GT500PP specific)
Besides a little rust on the fingers of the PP I don't see anything else abnormal with the clutch assembly. We've also already got a Mcleod RXT Twin disc setup ready to go into the car next week thanks to our good friends at Mcleod Racing.
We'll keep everyone posted.
Jared
