5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Brembo Issue
Old Oct 20, 2010 | 03:32 PM
wantgt's Avatar
wantgt
Default Brembo Issue
So the 2 month old 5.0 has been in the shop 3 times to have brake squeal looked at. Each time the shop says that they cant replicate the issue and I am starting to get really frustrated. So today after lunch I started looking at the rotor and ran my finger from the bottom edge to the top edge. About half an inch from the bottom edge there is a very noticable lip that has formed around the entire rotor. I went to the passenger rotor and checked that one and it was smooth all the way around. Could this lip be the reason why my brakes squeal when braking/driving/acceleration?
Old Oct 20, 2010 | 05:32 PM
MrSandman's Avatar
MrSandman
Are you sure the front brakes are squealing? My rear passenger brake likes to make noise. Tried cleaning it with brake cleaner to no avail.
Old Oct 20, 2010 | 06:09 PM
wantgt's Avatar
wantgt
I'm pretty sure that it is the front, and it doesn't squeal just under braking. Under slow acceleration as well as during normal cruising it makes so much noise. I actually looked at the rotor again after I got home and it is not a lip but rather a gouge all the way around my rotor. The brake guys near my house said it was normal for ceramic pads to gouge into the rotors. Doesnt make much sense to me but I guess they know.
Old Oct 20, 2010 | 07:13 PM
MrSandman's Avatar
MrSandman
I dont care what anyone says..
"Under slow acceleration as well as during normal cruising it makes so much noise."
THAT is not OK.
Old Oct 20, 2010 | 07:16 PM
wantgt's Avatar
wantgt
THAT is not OK.
Yea thats what I try telling the dealership too, just because it didnt do it the one time you drove it doesnt mean there isnt a problem.
Old Oct 20, 2010 | 07:34 PM
JIM5.0's Avatar
JIM5.0
So long as your breaks do not sound like this:
http://www.youtube.com/watch?v=wsPjL8SUAFc
Sorry, I could not resist.
I was actually tempted to link a Ned Beaty clip, but my better senses got to me
As for brake squeal, I noticed mine squeal in the morning, but it is really more of a squeak, and it goes away the more I drive.
I also noticed that on harder braking (not where the ABS kicks in), my steering wheel pulls to one side.
My car is more than a couple of months old, and I'm about to hit 3K miles (time for 1st oil change to get out the break-in shards). I wonder if I can have my dealer look at my brakes?
Old Oct 20, 2010 | 08:08 PM
SpartaPerformance's Avatar
SpartaPerformance
If the rotor has a high spot it can make noise even without stepping on the brakes.
Old Oct 20, 2010 | 08:28 PM
nemosgt's Avatar
nemosgt
Your steering may be pulling to one side if you have wider tires. Especially if you have 275s or greater on the front. This is known as tram-lining and can't be helped. Caused by uneven pavement/dips where big rigs brake hard for stoplights/signs. Try braking on smooth level areas such as parking lots etc. and see if you get the same results. Don't get security after you though. LOL.
With Brembos and performance pads you are going to see/hear some brake squeal. Seems to be the nature of the BBKs, but the OP seems to have more at work here. I would try an independant brake/muffler shop for a second opinion.
Cheers.
Old Oct 20, 2010 | 10:11 PM
thezfunk's Avatar
thezfunk
Did you bed your brakes properly?
Old Oct 20, 2010 | 11:38 PM
wantgt's Avatar
wantgt
yea I did, I just drove around my apartment complex at about 2mph and the squeaking was non stop, the more I listened the more it sounded like it was coming from the rear. The shield on the back of the rotor doesnt seem to be touching at all. Didnt have a jack to take the wheel off to check the pad to see if there was something stuck in there, but this is just really weird. I tried using my phone to record it but of course there was ****ty quality and nobody was around to listen to the noise to see if it was really the front or rear. The roads werent bumpy so I dont think it is a suspension thing specially since as soon as I tap the breaks it stops.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
