5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Rear end question...
Old Dec 30, 2010 | 10:41 AM
RickyBobby's Avatar
RickyBobby
Default Rear end question...
I got my 2011 GT used, no window sticker to be found. The dealer said he was 'pretty sure' it was a 3.73 rear end. Is there any way to confirm this?
(like running at a particular speed, seeing w/ the rpm is etc)
TIA
pdonket's Avatar
pdonket
Although I don't have the answer myself, you'll have a response shortly I'm sure from Nuke around here, who I believe has a spreadsheet of RPM to speed comparisons that tell you what type of rear axle ratio you're running
Old Dec 30, 2010 | 10:58 AM
dragline's Avatar
dragline
i believe there is a tag with this info on the differential - seems like i saw this posted in another thread somewhere...
Old Dec 30, 2010 | 11:27 AM
RickyBobby's Avatar
RickyBobby
Cool, I've done a search, can't find it.. Lot's of good threads though!
Old Dec 30, 2010 | 03:06 PM
zachcrosen's Avatar
zachcrosen
I was under mine last night and there is a tag on the diff that says the gear ratio. I had suspected mine was a 3.31 ratio and I confirmed it lay night by the tag.
Old Dec 30, 2010 | 03:22 PM
SpartaPerformance's Avatar
SpartaPerformance
The tag will tell you the gear ration on the differential. If for some reason there is no tag, if you have access to a lift the you can put a chalk mark on the drive shaft and spin the rear wheels, count how many times the rear wheel turn v the drive shaft.
Old Jan 2, 2011 | 09:15 AM
anadventurer1's Avatar
anadventurer1
The easiest way to check the gear ratio would be to look at the window sticker online. If your car has optional gears they will be listed under Optional Equipment. Just replace ...... in the following link with your VIN.
http://fordlabels.webview.biz/webvie...=......&ref=VL
Old Jan 2, 2011 | 09:25 AM
MrSandman's Avatar
MrSandman
That's pretty cool! Just saved my sticker to my computer. Not trying to thread hijack, but is there a resource out there we can use to get more detail regarding manufacture date, number..etc?
Old Jan 2, 2011 | 12:14 PM
hawkeye18's Avatar
hawkeye18
you can email crc@ford.com with your VIN and request a build sheet. They will send you, on nice 24lb paper, a sheet listing your build date, options, etc. It's pretty nice, and free.
Old Jan 2, 2011 | 01:05 PM
RickyBobby's Avatar
RickyBobby
Ok, I found my sticker online, it does NOT mention anything about the rear end gear under options. So I guess that means I have the 3.31??
