'06 GT Battery Issues
Been a while since I've posted here (read: broke college student, reading the forums only wants to make me spend my little funds on more mods)... however, this issue that has come up begs the advice of MF
Battery started dying last week on the way to the bar, radio went out, looked at the voltage meter and realized it was dropping quick. Made a quick U-turn and headed back towards my place, on the way back, full death - headlights/tach/speedo. It had been about a year and a half, so cleaned the corrosion off and bought a new battery, swapped it in. Was thankful it wasn't the alternator and dodged an expensive bill.
Flash forward 2 weeks, I drop two buddies off and I'm headed back towards my place. Notice movement on my gauges, I kill the radio and since my headlights are still on, I watch my battery drain to nothing while I just manage to coast into a parking spot at my complex.
Alternator? That's my first idea, but I can't understand why it worked for two weeks of night driving ( headlights/radio on /w no issues). Also, when I go out to my car in the morning, it has enough battery to start magically again, and doesn't drain quickly unless I turn accessories on.
Just kind of stumped, I figure it has to be an alternator issue at this point. If there's anything else I should consider, other than cleaning off corrosion, I'm open to ideas. Just trying to avoid a stiff bill.
Any threads y'all could link to (been googling all day and night trying to find similar issues, and short of turning off accessories and buying a charger I found nothing seemingly relevant) would be highly appreciated.
Sorry for the long post, just want to throw it out there before I drop what little cash I have to spare.
Cheers and thanks y'all!
I think you posted this in the 5.0 section...
Nonetheless, have your alternator load tested as well as the battery (despite being new). The alternator is a weak link in an already-iffy charging system. I've read numerous threads where the alternator was not dead but the charging rate was degraded which will slowly discharge a good battery.
Good alternator should be between 13.8 and 14.4 or so on the charge side at idle with no accessories and with everything in the car running, should be stable and fluctuate very little.
Probably. My experience is, when you have a dead battery, it's making the alternator charge it 100% of the time and that plays havoc with the diodes. If I remember correctly, it used to be that you could replace the diodes, but these days it seems you can't.
I'm not a mechanic, I just played one when I couldn't afford the services of the real deal.
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
