5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Anyone Removing the foam from the sound tube?
Old Feb 27, 2011 | 03:51 PM
ebaugh1990's Avatar
ebaugh1990
Default Anyone Removing the foam from the sound tube?
Is anyone removing the foam from the sound tube that ford put in the 5.0's for a louder in car sound of the engine revving?
Old Feb 27, 2011 | 04:08 PM
50mustanggod's Avatar
50mustanggod
Yea i took out the one in the firewall makes it A LOT better and its so easy to get to that one just pull it out from under the hood!! Makes it so you can hear that 5.0 SCREAM!!!!
Old Feb 27, 2011 | 07:15 PM
Dewyrussler's Avatar
Dewyrussler
Does it make it a lot louder, or just a little?
Old Feb 27, 2011 | 10:49 PM
Kixsters's Avatar
Kixsters
It does make it significantly louder but id rather hear the exhaust and no noises inside the car
Old Feb 28, 2011 | 01:27 AM
parchisi's Avatar
parchisi
You want to hear exhaust but no noises.......
Old Feb 28, 2011 | 02:18 PM
SLVSTNG09's Avatar
SLVSTNG09
Without the 2 foam pieces you can really here the engine scream.
I put the piece of foam back in the end of tube which goes into the cabin. With both pieces of foam out when you floor it you will get a slight dash buzz/vibration due to all of the extra noise. Sounds awesome though, but the vibration was driving me nuts.
Old Feb 28, 2011 | 05:19 PM
Norse1974's Avatar
Norse1974
Theres a video clip on youtube showing how to remove the 2 foam pads. Really crappy though to be honest! Doesnt show exactly where they pull them from. Anyone care to make a video of it being done for all us here?????
Old Mar 2, 2011 | 11:58 PM
Falcon Fixer's Avatar
Falcon Fixer
just remember that the sound tube enters the intake AFTER the air filter.
Old Mar 3, 2011 | 07:39 AM
AzPete's Avatar
AzPete
No problem.....read up on it and you find that it has nothing to do with air flow based on it's design. As if Ford would do that.....
Old Mar 3, 2011 | 08:01 AM
dcarlinf1's Avatar
dcarlinf1
First I removed the white foam at the front of the tube. That makes very little difference. Then I removed the black foam in the rear. It's much louder but does not sound natural with both pieces removed. I put the white foam back in and now I like the way it sounds. I recommend always leaving the white foam and only remove the black piece if you want the additional sound.
