Swappable Gauge Cluster?
I've got what I like to consider a "COPO" 2012 Mustang GT. It's white and only has two options, 3.73 rear and Brembo's. I'm interested to know that if I can get my hands on a GT Premium gauge cluster, will it fit directly (including wiring and function) into my base model interior? I know they are the same size and the premium has 2 more gauges amongst color changing stuff etc. but is it plug-n-play?
I think a tune will reprogram the electronic speedo read. But it has been so long since I read about Premium package gauge cluster to nonpremium package gauge cluster that I cannot remember if this is correct.
There is a thread on this swap but I just did a quick search and cannot find it. If someone has that thread bookmarked, please link it. I too need to read it again.
^ yeah I searched first lol. Good to know they didn't skimp on the wiring too. It's nothing I need immediately but if I come across one from a scrapped GT, I wouldn't mind the trade
My gauges are all black background and light up the Ford green/blue color with red needles. I only have two of the four center gauges up top. They don't do any magic tricks with the backlighting at redline either. I'm perfectly fine with all of this but if the timing and price is right, I wanna be able to jump on the chance for an upgrade.
The cluster will fit, the dealer needs to program the cluster to the PCM which will adjust transmission and speedo for gears. The dealer CAN NOT program the mileage, so you should find one with similar mileage or you can have the dealer send it out to get it programmed to your mileage
The cluster will fit, the dealer needs to program the cluster to the PCM which will adjust transmission and speedo for gears. The dealer CAN NOT program the mileage, so you should find one with similar mileage or you can purchase from a dealer and they send it out to a place that is certified to calibrate mileage
