5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
JLT vs. Mishimoto Oil Catch Can?
Old 05-02-2011, 02:24 PM
Truckbutt
Banned
Truckbutt's Avatar
Default JLT vs. Mishimoto Oil Catch Can?
Anyone have any opinions on which one is better? The JLT is about $30 more expensive with shipping.
Truckbutt is offline
Old 05-02-2011, 03:49 PM
hawkeye18
hawkeye18's Avatar
The JLT unit uses factory Ford hoses, which means install takes literally 30 seconds, tops, and they are ultra-durable (being Ford hoses). The Mishimoto unit has a sight glass (more like sight plastic), which I have found most useful as a source for a vacuum leak.
The JLT unit also honestly looks like it came from the factory there - that's how well it's engineered. I'd definitely spend the extra $30 - I did.
hawkeye18 is offline
Old 05-03-2011, 07:42 AM
Truckbutt
Banned
Truckbutt's Avatar
Thanks, I'm sold.
Old 05-03-2011, 12:37 PM
Riptide
Riptide's Avatar
http://www.conceptualpolymer.com
Better separators than either of the two the OP mentioned.
Riptide is offline
Old 05-03-2011, 03:11 PM
traxiii
traxiii's Avatar
Mine is from Speedair and I bought it from Graingers. Works great.
traxiii is offline
Old 05-03-2011, 09:43 PM
VistaBlue
VistaBlue's Avatar
What makes those better?
VistaBlue is offline
Old 05-08-2011, 02:09 PM
drboyd
drboyd's Avatar
I have to say that I really had to clench up tight to spend the money on the JLT, but having seen it up close and installed it, it's probably touching over on the "worth it" side. If it works half as well as it fits and looks, it's a deal.
drboyd is offline
Old 05-08-2011, 05:07 PM
hawkeye18
hawkeye18's Avatar
I would argue that there's a point of diminishing returns with these - how much oil do you realistically need to capture? The JLT unit captures well over 90% of the oil in the stream - is the last 5% worth 2x the cost? Plus, there is the fact that the JLT unit modifies stock Ford PCV hoses in its construction and maintains a factory look.
Old 05-09-2011, 06:43 PM
Riptide
Riptide's Avatar
Not only does the conceptualpolymer probably do a better job of capturing blowby than the JLT. It will store more of it before you have to empty the reservoir. I got real tired, real quick, of emptying my little husky separator every 200 miles. It may not be as big of a deal naturally aspirated but boosted cars seem to have significantly more blowby.
The JLT is not even close to half the cost of the conceptualpolymer. $119 vs. $155. And $155 with the conceptualpolymer gets you an extra filter, brass fittings, and the bigger reservoir.
Riptide is offline
Old 05-10-2011, 08:33 PM
92hatchLX
92hatchLX's Avatar
I'm waiting on my JLT one to come in now. Did a lot of looking around and the JLT had the easiest install, best fit and finish and holds plenty of oil IMO. $119 well spent.
92hatchLX is offline
Quick Reply: JLT vs. Mishimoto Oil Catch Can?
