5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
rough idle
Old 04-24-2012, 08:08 PM
Enochius
Enochius's Avatar
Default rough idle
I've had my car a week now and the idle is rough. It varies a couple hundred rpm's constantly. You can't feel the roughness but you can easily see it on the tach.
I've looked online and can't really find an answer. I'm hoping someone can tell me it's normal or if something is wrong.
Thanks
Enochius is offline
Old 04-24-2012, 10:57 PM
russellthelovemuscle
russellthelovemuscle's Avatar
hmm thats hard to tell becasue it could be so many different things. the first thing i would do is try to get my hands on a On Board Diagnostics (OBD scanner) to make sure all my sensors are good and the ECU is not shooting any codes. but usually if that were the case you would get a check engine light. next thing i would do is a quick check of the car like check out the air filter, maybe replace the fuel filter, look and hear for anything out of the norm
russellthelovemuscle is offline
Old 04-25-2012, 11:05 AM
Enochius
Enochius's Avatar
Now it feels like I'm down at least 200 horsepower. The car has no go and feels like a 4 cylinder.
I think it was some bad gas or something. I filled it up on my lunch break and then after a few miles it straightened up. I was getting worried!
Enochius is offline
Old 04-25-2012, 05:53 PM
shoeys08dkcandygt
shoeys08dkcandygt's Avatar
How's the car now? Any better? What part of TN are in
shoeys08dkcandygt is offline
Old 04-25-2012, 08:33 PM
Enochius
Enochius's Avatar
The idle issue seems to be normal. I found an article saying that it had something to do with the variable timing. It seems to be running normal again to. I don't know what happened. I live close to Knoxville, tn
Enochius is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: rough idle
