Custom Catchcan Setup I made for my dads mustang
#21
454whp??
Just curious, how do you handle torque steer? What kind of diff do you run? Steering? Suspension?
I am a retired Engineer and for the life of me I can not figure out how you could get the car to go straight.
#22
It actually runs really straight I've never had a problem with torque steer. I run a Torsen T2 Diff, and a stock steering rack and some B&G coil overs.
#24
so quick question.. Your saying the design of the jlt and everyone on the market is designed wrong? because I have the JLT and I have had it from 1000 miles and the oil and oil vapor it catches keeps all that junk out of the intake manifold ( I have taken it off before and checked at 10,000 miles and it was bone dry). So I see what you are saying but in theory it will work the same if it were returned to the manifold vs the driver side.
#25
#26
So want to give a parts list, where to buy/prices and some dimensions on the pieces?
Also wouldn't be better to pull a vacuum on the PCV by running a tube down to get a venturi effect? Or installing a 12 V fan accomplish the same? Engines have been pulling a vacuum on the PCV system since at least 1965, while opening it to atmosphere will vent crank case pressures it is not as effective.
#27
As for your vent to atmosphere not being as effective it has already been covered in this thread, It is very much effective.
#28
Sorry i will not be giving out dimension or a list of parts. I will be selling these on here as soon as the admin gets back with me. I can send you a list of everything that is included if you are looking to purchase.
#29
Venting is a good idea. I think electrical heat shrink for a 250 to 500 mcm cable would work for attaching to the factory fittings. It would be nice to adapt an AN fitting to the valve covers - any ideas? A set of sheet metal valve covers would go very well with this setup
#30
I may taken them off over July 4th holiday to check out the valve train and will take pics.
