2013 Hood Pins
Don't listen to the nay sayers.
When you get them, give them a good test fit and look at them from all possible angles.
If YOU like them, get to drillin!
The only one you have to impress... is you.
I put a custom shift **** on mine, and no my OEM shift **** wasn't broken. My hood stripes were just fine when I removed them too.
As far as my exhaust goes, I can just pop the factory exhaust back on when I want to. The spoiler was free since my car was ordered with a spoiler delete. It is pretty much a given that 99.99% of spoilers are just cosmetic, so I went with it.
Good luck.
i have "nose rings" on my 12 and absolutely love them!
Honestly...i think the hood on the 13's is ideal for hoodpins...just keep them to the outside part of the hood and off the big raised center area and you'll be fine!
I would question the actual need for them, fluff? Do the cables move around in the wind and damage the paint? Its your car so what you like is the only thing that matters. I kinda put these in with the rear stick on brake scoops that do nothing except create more drag. I would not install the pins if it was me. It makes the car look comical in my opinion.
DUDE!! Your car looks so bad ***! i love the way it looks yup im doing the pins for sure! Thanks everyone!
You can do whatever you please, it's your car. I just don't understand the purpose. Hood pins are meant as quick releases for lightweight hoods on race cars. The hood on the Mustang is not particularly lightweight. They may make it harder to sell the car down the road as well.
Good luck.
Good luck.
Yes, the headlights and fogs (in the pic posted) are smoked with a vinyl kit from Big Worm Graphix.
http://www.bigwormgraphix.net/. They also have a layer of clear vinyl that was part of my clear bra install.
I deleted my fogs no too long ago and opted for custom made inserts...MUCH better airflow...dropped coolant temp about 5-8 degrees
not to keep this silly argument up but i plan on keeping the car till the wheels fall off. Your logic doesnt make since to me. so if 99.99% of the people put hood pins on you would be fine with doing it? There is no purpose except cosmetic for the hood pins. just like there is no purpose for your spoiler. Like i say to each his own but dont downgrade peoples ideas or modifications when you are guilty of it too.
