5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Hard Shifting From 1st to 2nd?
Old 05-27-2013, 08:51 PM
Juice5.0
Juice5.0's Avatar
Default Hard Shifting From 1st to 2nd?
I have a 2012 GT, 6 spd, with an aftermarket hurst shifter. When I accelerate hard it has a hard time shifting from 1 to 2....as if 2nd is "locked out." Anyone have this issue? Suggestions?
Thanks.
Juice5.0 is offline
Old 05-28-2013, 02:07 AM
WARHEAD.BR
WARHEAD.BR's Avatar
Thanks.
I got the same problem on my 11 GT stock, im veteran stick shift driver, but sometimes i feel that i change the gear before the clutch engage, im not sure if im the problem or the gears.
WARHEAD.BR is offline
Old 05-28-2013, 05:42 AM
mapitts
mapitts's Avatar
I swapped out my transmission lube to Redline MTL. Helped quite a bit. I also changed the shifter to an MGW. It replaces the entire shifter. Box, rear supports and all. I am not sure what all the Hurst replaces. I am a veteran manual driver as well. IMHO a hydraulic clutch just does not give you the feel the good old mechanical clutches did. Everything has gone hydraulic though. It is what it is.
mapitts is offline
Old 06-03-2013, 07:24 PM
miner999r
miner999r's Avatar
r u running into the skip shift function. This was deleted in the 13 cars
miner999r is offline
Old 06-05-2013, 05:43 PM
jdos1
jdos1's Avatar
The issue is likely your shifter and the stock fluid.
I had the same issue with both of my MT82's. On the second I swapped out the fluid for Amsoil MTG which helped a little. After installing an MGW shifter, all notchiness/shift issues were resolved and I've began to like these transmissions.
jdos1 is offline
Old 06-05-2013, 08:09 PM
JIM5.0
JIM5.0's Avatar
Agreed with the posts above to change the tranny fluid. Ford even issued a TSB to change the fluid to address this rough shifting.
If you don't want to change the fluid yourself, you can take it to the dealer during your next oil change or whatever, and ask them to change the fluid as per the TSB for the MT82 gearboxes.
JIM5.0 is offline
Old 06-20-2013, 01:01 AM
joe95 gt
joe95 gt's Avatar
Thanks.
I have the same year and shifter as you and the same issue also, let me know if you find a good fix.
joe95 gt is offline
Old 06-20-2013, 12:03 PM
BrazenStang
BrazenStang's Avatar
^ This if the conditions are right. What RPM are you completing the shifts at? Look at your information gauge in the Speedo. It flashes "1 -> 4 Skip Shift" and then it will lock out 2nd gear.
BrazenStang is offline
Old 06-21-2013, 04:17 PM
WARHEAD.BR
WARHEAD.BR's Avatar
so its a feature? that suck... i got to pay more attention if in sport mode ill still do.
Old 06-22-2013, 08:26 AM
mapitts
mapitts's Avatar
Thanks.
Which shifter do you have? If you can provide a link, I would like to see what all the shifter came with.
mapitts is offline
Quick Reply: Hard Shifting From 1st to 2nd?
