5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
TSB & Factory Warranty
Old Mar 17, 2015 | 11:13 AM
Slowbra302's Avatar
Slowbra302
Default TSB & Factory Warranty
Quick question. Took my car in for an alignment and to check a couple things out. Since I just lowered the car and swapped out struts and got CC plates, I get this "squeak" that sounds like a bird chirping from the driver side strut tower area. This is only pretty when it's like 75+ degrees outside and the motor is hot.
My service manager mentioned the TSB for the lower control arms. Then after reviewing my mileage (40199.8) he said since the 3/36k warranty is up If they did find an issue I would still have to pay out of pocket.
I thought TSB's were at fords expense regardless if I had warranty? Could anyone clarify?
***EDIT*** TSB's are informational and not a recall. My mistake!!
Old Mar 17, 2015 | 08:00 PM
jz78817's Avatar
jz78817
yeah, a TSB basically is a heads-up to dealer techs that "this might happen, if a customer complains about (issue) look here first." it doesn't mean every car has that problem. AFAIK only recalls and extended service coverages go past the factory warranty.
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
