5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2014 5.0 doesn't feel much faster than my old 2005 4.6???
Old 08-23-2016, 10:55 AM
  #31
P51C
P51C's Avatar
The stock 3V heads flow pretty well and come close to the 4.6 4V Cobra/Mach 1 heads, but the Coyote 5.0 heads are something else altogether. The biggest choke point on the 4.6 3V are the stock cams so they'd definitely have to go. The best stroker option might be:
1. Rebuild the existing 4.6 engine with a forged 298ci (or 302) stroker kit and upgrade to a billet oil pump.
2. Have the stock heads CNC ported with 3-angle valve grind and upgraded valve springs/retainers.
3. Add performance cams.
That's true but the above option should save a fair chunk from that.
Alternatively, you could just leave the stock 4.6 engine alone and slap a blower on it while setting yourself a 450rwhp limit.
I think we are really in apples and oranges comparisons here. Building the shortblock is an option with both engines and smart if you're going for a max effort build. However, the Coyote has proven to be a really solid performer even with the stock bits inside, WAY over what the stock 4.6 whirly bits can handle. Not too many people looking to build a 1000 hp car so, starting with the Coyote stock as a base is a way better starting point, as less is required to get to where you need/want to go. 450 wheel is in the doable range for a coyote n/a, with relatively low mods and cost. CJ mani w. TB, matching CAI, full exhaust, OPGs, maybe a billet camshaft set and a rocking tune.
P51C is offline
Old 08-23-2016, 12:19 PM
  #32
Norm Peterson
Norm Peterson's Avatar
This much was my impression the first time I saw the power and torque numbers for the 4.6 3-valve. They just weren't all that much off from what the earlier 4.6 4-valve had made (at least in stock form), and the later FRPP/Bullitt/2010 states of tune narrowed even that small gap.
But they aren't in the same league as the Coyote heads. One look at the specific torque numbers gives that away (78 ft*lbs/L for the Coyote, 70.5-ish for the 4.6).
I'd rather have a Coyote with the 4.6L's shorter stroke (for 293 CI) than a 298 stroker. Should eat any given car with the slightly bigger stroker motor alive, assuming NA in both cases. Probably not much cheaper to build, though. Custom-length rods, for one thing.
Norm
Norm Peterson is offline
Old 08-23-2016, 02:19 PM
  #33
Dino Dino Bambino
Dino Dino Bambino's Avatar
IMO the most viable route to a Coyote swap into an 05-10 GT is to buy a wrecked '11-14 GT to use as a donor car, scavenge all the juicy bits, and sell the leftover parts.
Dino Dino Bambino is offline
Old 08-31-2016, 01:05 PM
  #34
flash_xx
flash_xx's Avatar
If I ever do decide to spend an ungodly amount of money on my car the first thing would be a T56 and a Brenspeed B326 with ported heads and cams. That should come close to a
Coyote in power at a lower price plus less hassle with the electronics. Also the T56 beats that crap the Coyote comes with.
flash_xx is offline
Old 09-05-2016, 06:33 AM
  #35
Dino Dino Bambino
Here's a dyno sheet of a three-valve 323 stroker with full bolt ons. At 426rwhp & 384rwtq it matches the outputs of a Coyote 5.0 with a CAI, LT headers, exhaust, & tune.
Attached Thumbnails 2014 5.0 doesn't feel much faster than my old 2005 4.6???-c-and-l-stroker-323.jpg
Old 09-06-2016, 10:08 AM
  #36
P51C
P51C's Avatar
Impressive....if someone else is footing the tab, because the Coyote needs less than 2K worth of relatively minor bolt-ons to do that. Hmmm....
P51C is offline
Old 09-29-2016, 12:18 PM
  #37
flash_xx
flash_xx's Avatar
You're assuming the car already has the Coyote. We were taking about a swap. A Coyote swap is more money than modding a 3V. Plus all the electronics hassles and that crap of a manual trans.
flash_xx is offline
Old 11-26-2016, 12:40 PM
  #38
tbear853
tbear853's Avatar
Read the whole thread .... LOL .... all those 1/4 mile ETs and MPH numbers ain't what makes a car a pleasure to drive. What makes the car a true pleasure is the "feel". It's all purely subjective then. Things that can affect that feel often are not so easily measured by a stop watch or have anything to do with trap speeds.
tbear853 is offline
Old 11-27-2016, 10:17 AM
  #39
Norm Peterson
↑↑↑ So true.
Quarter mile stats are irrelevant to any street driving that isn't a street race.
And not the be-all, end-all to running decent lap times on a road course either (where high-speed high-intensity driving belongs). 110-ish mph in a straight line for a stock 5.0 S197 . . . (insert big yawn here) . . . there's at least one turn at Mid-Ohio that I drive through faster than that and another at NJMP where I'm getting close to that speed at the track-out cone.
Later edit - doesn't look like OP has ever checked back. Joined, posted, and went MIA all in the same day.
Norm
sonic245
04-20-2016 08:40 AM
robriley3474@gmail.com
03-17-2016 09:51 AM
Mr. D
The Racers Bench
02-13-2016 12:09 PM
BurnThis
06-12-2003 12:50 PM
cchris1109
04-19-2003 07:43 PM
Quick Reply: 2014 5.0 doesn't feel much faster than my old 2005 4.6???
