5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Tapping into headlight power
Old May 9, 2018 | 08:02 PM
whudson1980's Avatar
whudson1980
Default Tapping into headlight power
Ok, I'll make this brief so you dont get bored.
I'm a firefighter and have several interior lights. All low power LED. I have 2012 GT. I'm looking for directions on how to tap into the ignition power so the lights turn off when I turn off the car.
On my 2003 GT, I tapped into the fog lights. So when I powered off vehicle, and turned lights off, the lights shut off.
any insights?
Old May 10, 2018 | 05:06 AM
08'MustangDude's Avatar
08'MustangDude
Banned
There are all kinds of power taps in your engine bay fuse/relay center. Some are on all
the time, some are on with ignition. Kind of looks like this:
All those male spade tips, check them for power, car off, and on.
Go to walmart and buy a $20.00 volt meter, and test for ignition voltages
inside the car too. You will have one right at the radio harness, for one.
Old May 10, 2018 | 05:15 AM
whudson1980
Yes, I'd be looking to do it interior, not engine bay. Radio wire harness I'd a great idea. Know the specific location, and which wire would be power and ground?
Old May 10, 2018 | 05:38 AM
08'MustangDude
Banned
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Old May 10, 2018 | 11:12 AM
whudson1980
You're a Godsend! Last question, I promise. Lol. Where is this harness located? It's a stock radio. Behind radio, or more towards fuse box? Any tricks at getting to it easily?
Old May 10, 2018 | 03:35 PM
08'MustangDude
Banned
It plugs into the radio, so directly behind it...
If you have a fuse box inside the car, I am sure you can pick up an ignition
power source there... Just use a volt meter, check fuses with power off,
when you find one that does not have power, put the key in ACCY and RUN
positions and test that fuse again for voltage. The fuses have expose test
points on them, they all do.
vbrecken
Feb 3, 2025 07:46 PM
sleeping stallion
26
Feb 6, 2008 01:06 AM
boostanggt
Dec 25, 2007 08:52 PM
dramsey
Aug 19, 2007 10:03 AM
Action_Jackson
Oct 15, 2006 03:33 AM
