2015 GT mt-82 in 2013 mustang gt.
Hey all, I’m needing a new transmission for my 13gt. I’ve found one going for $1200 with only 7k miles. It’s been tracked, but everything appears to be in working order. Comes with a good clutch and flywheel. I know that the shifter assembly has to be swapped, as well as the 3 bolt flange for the 15 transmission, but is there anything else that would prevent this transmission/clutch/flywheel from working in my 2013 gt? Thanks!
I can't answer your specific question, but want to say don't forget to do the crank relearn process after you separate the engine and transmission. If you don't do it after putting it back together you can have major problems.
Stangfreak2002
Feb 21, 2006 11:57 PM
