hey yall i was just woundering with the bolt pattern is for the flywheel in the 3.8 im going to be getting a new clutch and i was told i can use a gt assembly
thanks in advance guys
Why do you want the GT clutch/flywheel in the first place? I think I heard that the cobra flywheel is the same as the GT flywheel... Now Im confused as hell.
I was under the impression that you needed a v6 spec aluminum flywheel in order to use a gt clutch. The spec flywheel has bolt holes for both a v6 and gt clutch.
