Archive - Trades & Freebies If you are looking for a trade, or have something to get rid of, no money involved, post it here.
1994 Ford F-250 XLT 15" Lift 42" Tires WICKED
Old Apr 24, 2008 | 05:03 PM
FBStang82's Avatar
FBStang82
Default 1994 Ford F-250 XLT 15" Lift 42" Tires WICKED
1994 Ford F-250 XLT
351W/Auto Trans, 140k miles
K&N Filter
Throttlebody Spacer
Trans Cooler
Dana 60 Kingpin Front Axle (rebuilt)
Ford 10.5 Full Floater Rear
WARN Hubs
1 Ton Axles
4.56 Gears
Detroit Lockers front and rear
Front axle shims/wedges
Front drop shackles and hangers
Drop Pitman Arm
New tierod ends
Cross-Over steering
NEW Pro-Comp (4) Shocks and steering stabalizer
Custom center bearing brace
Axle-wrap eliminators
15" Lift
42" Super Swampers
Eagle Alloy Rims
2.5" Exhaust from Y-pipe back with Cherry Bombs
5" Stacks
Clear Corner lights
Grille Inserts (lights behind)
Autogauge Tach, etc.
Floor mounted fire extinguisher
New door hinges (no sag)
Bed Tool Box
Diamond Plate bed rail caps
Reese hitch reciever
8" Drop Hitch DOES NOT COME WITH THE TRUCK
Pioneer CD Player
Pre-wired for CB and stereo amp
Dual gas tanks 15? 16? gal each (rear needs the pump fixed)
Truck is WICKED!!!
Windshield is cracked
Front right locker needs work (pin and end?), have a spare just havnt had time to put it in
Driver's side mirror is cracked
Small exhaust leak
Fan shroud needs to be put on (should just add dual electric fans)
Tail gate needs a piece in the handle to open
Steering should be adjusted (rubs on leaf spring on too sharp of a turn)
Caliper needs to be replaced front passenger side (bleeder was broke off flush)
There is a leak between the trans and transfer case, pretty damn sure its only a seal (leaks fluid constantly)
Check engine light comes on after driving for a little while (O2 sensor was replaced by last owner, light went off for a little while, then came back on. Havn't hooked it up to a computer following that)
Currently, I drive the truck daily
http://www.fourwheeler.com/eventcove.../photo_08.html
Picture of it in the Real Truck Challenge in the Badlands IN. Have to have a very good, highly respected, and selected truck to compete in that. Truck is no doubt a GREAT competition truck.
Truck is AWESOME!!! Really COOL and FUNNN ride!!
I have described the truck to the best of my ability. Purchaser responsible for inspecting the truck. Sold AS IS, WHERE IS. No exceptions.
Old Apr 26, 2008 | 03:55 PM
mustangballer20's Avatar
mustangballer20
Default RE: 1994 Ford F-250 XLT 15" Lift 42" Tires WICKED
how much?
Old Apr 28, 2008 | 06:49 AM
FBStang82's Avatar
FBStang82
Old Sep 27, 2008 | 10:00 AM
FBStang82's Avatar
FBStang82
msavoia23
12
Jul 7, 2018 12:08 PM
drfister
May 3, 2018 10:38 PM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
Stilz
Aug 19, 2015 06:17 AM
ccwebb
Aug 11, 2015 06:47 PM
