Alternator whine isolators????
Old Mar 2, 2006 | 02:58 AM
Jimmz's Avatar
Jimmz
Default Alternator whine isolators????
I just recently purchased a Optima Yellow top battery and it actually took away most of my alternator whine, but I want it completely gone and I dont want it to come back, will this really work? Its an isolator that supposivley filters out the any noises between your deck an ur amps.... ive heard of noise filters an such but ive never heard of this particalur isolator, if anyone has any feedback or knows anything about this please let me know thanks....
Does this really work?
Old Mar 2, 2006 | 03:08 AM
Sinister Audio's Avatar
Sinister Audio
Default RE: Alternator whine isolators????
sometimes they do but it could be alot of things. bad rcas, bad ground, certain amps will add a whine, how you have your wires ran, what kind of deck do you have cause a bad ground there could add noise.
Old Mar 2, 2006 | 03:17 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
It could be because your rca's and ground crossed...buy some new rca's and try it
Old Mar 2, 2006 | 04:49 AM
Jimmz's Avatar
Jimmz
So you guys think its worth it? its only $12 with shipping....
Old Mar 2, 2006 | 05:22 AM
Sinister Audio
it might help but i dont think it will. you can get some decent rcas for 12 bucks too.
Old Mar 2, 2006 | 11:37 AM
Danbert's Avatar
Danbert
I have used one of these before. It works on the principle of filtering frequencies common to alternator whine. So think about this. if it is filtering frequencies out of your signal, isn’t it also degrading the accuracy of your system over all? I have found this to be true in testing. I added this unit to a system that had no whine, then tested the system with both an audio control RTA and an oscilloscope. There was a measurable drop in certain frequencies. Forgive me for not being able to list those frequencies affected off the top of my head. But any change to your signal will effect the over sound quality. Your best bet is to take the time to go through your system using troubleshooting techniques to find the source of the problem and then taking care of it properly.
Old Mar 2, 2006 | 12:38 PM
1fastzook's Avatar
1fastzook
you might need to re ground the h/u.sometimes if you use differnt brands or cheap rca's or power wire next to the rca's all of these can cause engine noise.what kind of h/u do you have?
Old Mar 2, 2006 | 04:45 PM
Jimmz's Avatar
Jimmz
I have a clarion dxz945mp deck, I changed out the rca's twice and it finally went away but it came back a while later... I even changed the ground it isnt as bad now but I just want it completely gone.... heres the deck I have...
[IMG]local://upfiles/5195/14A1366C0D95438D848A0FC245229011.jpg[/IMG]
Old Mar 2, 2006 | 06:37 PM
1fastzook's Avatar
1fastzook
i have seen where if the factory harness is close to the rca's caused engine noise or "alt wine" try to move the fact harness away from the rca's.get a spare peice of wire and put to a good ground on the body and touch the other end to the case of the radio.also if you radio has a dc converter box on it it can cause engine noise.its a wire that is attached to the radio on the one end and the other end is a little metal box.what kind of rca's are you using?
Old Mar 2, 2006 | 06:47 PM
Hisss04Cobra
says hiththth
If it went away when you replaced the RCA'S then their is a good chance your rca's and ground keep crossing...
