installing amp
Old Feb 18, 2004 | 01:17 PM
southerncomfort82's Avatar
southerncomfort82
Default installing amp
I have a '03 GT with a Mach 460 system. I am wanting to install an amp and sub in the trunk. Does anyone know where would be the easiest place to splice into for the input for the amp? Thanks.
Old Feb 21, 2004 | 03:29 AM
Fourtwozero's Avatar
Fourtwozero
Default RE: installing amp
get a amp wiring kit, it should come directly from your battery.
Old Feb 21, 2004 | 04:03 AM
Choppa's Avatar
Choppa
jus run a new wiring kit back and dont go through the mach system it will sound much better and much easier
Old Feb 21, 2004 | 10:07 PM
southerncomfort82
fourtwozero, I was actually refering to the audio input. Where to tap into for the actual music that goes into your amp. by the way, I like the name....
Choppa, So are you just suggesting that I find the right wires on the back of the head unit rather than possibly splicing into the back speakers?
Remember: I have the stock head unit. Im not sure, but i assume there aren't any RCA jacks on the back of it.
Old Feb 22, 2004 | 07:01 PM
Choppa's Avatar
Choppa
o i c ya it wont have rca jakcs so i guess you have to do it your way thats all i can think of
Old Feb 24, 2004 | 11:43 AM
Pitviper100's Avatar
Pitviper100
just run a kit from your battery back to your trunk... dont splice ne where into the factory system at all...
Old Feb 24, 2004 | 11:44 AM
Pitviper100
ohh and if your talking about the music input itself there should be inputs on the back of your cd-player if not time to upgrade...
they should be red n white inputs on the back or at least one of em should be red
Old Feb 24, 2004 | 05:22 PM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
if you haven't already, the piece you need is an sni-35. you will need the 35 because the speaker inputs you splice from are amped. yes use the speaker inputs off the back speakers, the power supply and ground are completely separate. you will need to run bat. to trunk for your power, i recommend nothing less than 8guage. you need to ground to the body, better if framed, but body will work for just a low pass amp. make sure you scrap the paint off the trunk floor for the ground.. use a multimeter and find the switched power(power only on with the key turned) on the factory amp. splice it for your remote.
pm me if you have more detailed questions. i am mecp cert. installer
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Art161
Sep 9, 2015 10:33 AM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
