Speakers making clicking noises
Old Mar 11, 2006 | 09:17 AM
Mustang In Paradise's Avatar
Mustang In Paradise
Default Speakers making clicking noises
It started in the front pass. door speaker, so i thought it was blown. then it started coming from both back speakers. i left the radio off for a couple days, then it was gone, systen sounds fine. is it a wiring issue you think? now i'm starting to hear it a little bit again. '04 6cyl
Old Mar 15, 2006 | 12:14 AM
H@yst@ckSt@ng's Avatar
H@yst@ckSt@ng
Default RE: Speakers making clicking noises
I have a 96 stang and i had similar problem with my speakers. Do you have an aftermarket head unit? If so i have an aftermarket head unit/stereo and i had same problem what i found out was that whoever installed it didnt bypass the factory amp so it caused the clicking noise that i was hearing. also if u remove door panel the plastic liner on the door causes a distortion noise such as clicking. i removed it and lined the door with the dynamat door kit and it solved the problem. hope this will help.
bjdutch2005
Mar 24, 2017 03:38 AM
Dragonus18
Sep 9, 2015 01:21 AM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
