Sub + Amp issue
Old Mar 17, 2006 | 04:31 PM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: Sub + Amp issue
you guys aren't referring to a remote start/car alarm that i don't have are you? i had circuit city hook everything up. i got some great news too. most of the people at the car audio place was fired and nobody was there right now. i thought it was funny when i'd call and hit option 2 for car audio installation and it just reset the menu every time. i guess they finally got caught red handed stealing the crap they install. i'm going to go for a ride tonight and have my gf look at the amp while i drive.
Old Mar 17, 2006 | 05:46 PM
1fastzook's Avatar
1fastzook
you might want to check your groud too and also beat the top of your amp and see what happens it might be a bad amp.
Old Mar 18, 2006 | 02:19 AM
nanaki's Avatar
nanaki
ok. had my gf watch the light on my amp. when i'm stopped, it's lit up. as soon as i start moving, the light goes off, as does that wonderful bass. someone said something about noise cancellation? i've never heard of it, but he says unless it's disabled, it'll cut power to the amp or something when i start moving.
Old Mar 18, 2006 | 02:21 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Well, go from the amp back then.
Old Mar 18, 2006 | 02:59 AM
nanaki's Avatar
nanaki
i'm hoping it's something really simple and the amp isn't actually messed up. it's obviously getting power and it works fantastic when i'm sitting idle. something is being fed to it when the car starts moving that just kicks it off. anyone have any ideas where i should start looking first? going to start messing with it tomorrow morning... afternoon... when i wake up.
Old Mar 18, 2006 | 03:17 AM
Hisss04Cobra
says hiththth
Start at the battery, and work your way back. Maybe replace the RCA'S...see what happens, that would probobly be the easiet solution.
edit: I bet it is your rca's now that I think of it, something similiar to this happened to me...but it would cut out everynow and then, not always...
Old Mar 18, 2006 | 12:38 PM
1fastzook's Avatar
1fastzook
check to see where your turn on wire is hooked up.do you have a glass fuse?some times the sodier joints in the fuse and will cause it to shut off.I see it all the time.if you can put up pics of you wiring
Old Mar 19, 2006 | 01:08 AM
Danbert's Avatar
Danbert
Just a suggestion, Hook a VOM up to teh power and ground connection, drive, see if you are loosing actual power. then hook it up to the remote turn on and ground to see if you are loosing that. This will allow you to determine which thing you are losing. You stated that it is lit up at a stop and not when moving, this tells me the amp is losing either power, ground, or remote turn on. I would think it is your RCA's only if the power stays on to the amp and you are losing sound at that point.
Old Mar 19, 2006 | 02:52 PM
kingcobra03's Avatar
kingcobra03
heres the deal you are loosing power to yu remote amp wire as soon as u start moving not uncommon with a amatuer install i actually see it a good bit. Wat u need to do is where ever u have hooked the remote power wire to a 12 volt source u need to find a alternate source making sure that where ever you decide to hook it to only has power when the car is running and it has power ALL the ime the car is running where u have it hooked o now has power while the car is running but while its sitting still like a brake light only has power when you are on the brakes (stopped or slowing down) hope this helps as i am sure this is the prob if you wanna check to be sure this is the prob before u try to relocate a power source unhook the remote wire and run a wire straight from the battery positive terminal and to the remote hook up on the amp and drive the car around i bet youll have bass and again i hope this helps ya...
Old Mar 19, 2006 | 03:07 PM
nanaki's Avatar
nanaki
actually. that was the problem. they had that one wire wrong. i took it back and had them fix it for free. no sense in me ripping apart my janx for their *** up. it works now though.
