My Interior...Opinions?
Old Mar 19, 2006 | 06:55 AM
Bigmack6933's Avatar
Bigmack6933
Default RE: My Interior...Opinions?
ORIGINAL: jesterj99
Looks alright man nice work.....get some new seats some reacers or something delete your rear seat and change out the interior fabric finish out your interior since you started with that.
WTF did you just say? can you clear that up please
Old Mar 19, 2006 | 11:23 AM
yobrandon's Avatar
yobrandon
Mines a 01, I believe anything prior was two seperate decks. See attached pics..
This is from a 00 i believe...
And This is a 01..same as mine..
Old Mar 19, 2006 | 06:35 PM
67Sally's Avatar
67Sally
I like the screen. Not a fan of neons but whatever...the gauges are pretty cool too. I wouldnt be done there if I were you (if you intend on keeping the car for much longer) but youve done a really good job so far. Keep it up
Old Mar 19, 2006 | 09:47 PM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
ORIGINAL: yobrandon
Word! No flames! Lol...Being new to the forum, i didnt know what to expect from you guys. I was dying to put a Kenwood ddx-7015 in my stang when i first saw them. But got scared when reading on the net about all the "mach 460 problems", ya know with aftermarket headunits and whatnot. Im here to tell you now....DONT BE SCARED..its really easy and simple. As far as the double din fit. All i did was put the kenwood mounting sleeve into the space..folded the tabs to secure it..and at this point theres a .25 of an inch gap around the harness...slid it in..placed some strips of electric tape on the sides (vertical) and placed the trim ring on. Ghetto yes i know, but you really cant tell the gap is very small. Then proceed to place the vent panel back in place. And voila it looks good. As far as the wiring harness..i just got the metra 70-5519 wiring harness. You can get them here.. http://www.partsexpress.com/pe/pshow...number=265-790 . So yes..it is possible to fit one of these in yours. I promise Thanks for the compliments guys, I guess ill stick around these forums for quite a while now.
Brandon
Heres some more pics..And larger..
Heres the specs for the interior...
Kenwood ddx-7015 with stock mach 460 amps/speakers/etc. (excluding the 15 in the back :P )
Kenwood Sirius Satellite Radio Tuner For headunit
Ps2 with wireless controllers (with ford mustang racing, ford racing, and all need for speed underground/most wanted games on hand )
Reverse Glow Gauges
Underdash neons
Neon Inside Glovebox
BADASS!!
I think I will do the same setup as far as neon... I already have the PS2 and the clarion touch screen dvd/cd combo and blue will go good with my screen, when it's in or out...
what do you guys think?
RAWR!! you will send me the link to get those ice blue guages!!
[IMG]local://upfiles/30869/F59CFCF9CC3248F092EAF972BF862C83.jpg[/IMG]
[IMG]local://upfiles/30869/CD4A9CBBD45A4E9B92D7DB63DCFB7334.jpg[/IMG]
Old Mar 19, 2006 | 11:55 PM
Nevada95's Avatar
Nevada95
I think your setup looks pretty nice. I recently installed a cd/dvd/mp3 player in mine as well, but it doesn't have the monitor. I bought a monitor that retracts to fit into a single din slot that should hopefully show up tomorrow. so I can install it I have the two din slots to fill so I just bought two seperate units.
I am running off the mach 460 system with my unit also. I need to add a little more bass though. Just one more thing to add to the list
How hard were those gauges to put in? I did some on some other cars and they were always a pain to try to get on without taking the needles off. I have been hesitant to try on my mustang because of this.
I noticed on the mustang, these guages are often sold with a tool to pop the needles right off. On other cars I was always told to not remove the needles because it was difficult to get to the proper setting.
Are the needles a pain to put back to their correct setting?
Have you had any problems with the needles sticking to the guages?
If you didn't have problems...where did you buy your guages from?
Old Mar 20, 2006 | 04:19 AM
yobrandon's Avatar
yobrandon
They are not actually hard to install. I got em off good ole ebay. Here...
Mine didnt come with any tools for the needles. I took mine off by hand. MY ADVICE...
Is to take pics of the gauges while the car is running at idle before taking the needles off. Turn off car obviously,..go through the steps removing the cluster etc. And remove the needles. overlay the new white gauges over the old gauges..plug cluster harness back in..so you can align the "service engine" lights n stuff while there lit. And then proceed to gently push the needles back on in the positions in the picture.
Hope this helps!
Old Mar 20, 2006 | 09:39 AM
tool fan's Avatar
tool fan
G'Damn, bro that looks tight, I am not a fan of the playstation and neon lights but it looks good none the less. I am looking at the kenwood system as well. How hard was it to remove the stock head unit???? The stock has to go, my bimmers have MP3 playback capability so this sucks, need this Kenwood DVD set up
Old Mar 20, 2006 | 09:59 AM
Danbert's Avatar
Danbert
Has anyone here tried to put the 01 trim ring in a 00? I have the 00 like he has pictured with the two offset openings. What would it take to modify the dash to make this work?
Old Mar 20, 2006 | 12:30 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
X-a on the Neon-a
Old Mar 20, 2006 | 03:32 PM
yobrandon's Avatar
yobrandon
ORIGINAL: Danbert
I believe That even though the trim ring seem like its the only difference. Theres brackets behind it. That still keep it 2 single dins. Im not sure if it can be modded or not. If i had this setup..id probably get one of the alpines that are two seperate decks, ones the flip out screen, ones the dvd drive. There nice. Something like this...
