No audio from amps please help
Old Mar 26, 2006 | 10:41 PM
joey_corleone82's Avatar
joey_corleone82
Default No audio from amps please help
hey everybody today I replaced my Mach 460 headunit. I have a 2001. I used the Metra harness METRA 70-5519 FORD 2000-2001 AMPLIFIER INTEGRATOR PLUG. I have hooked everything up and only get sound out of the 4 tweeters, but not the other 4 speakers (subs)
The amp piece of the harness has 2 blue/white cables labeled amp power, and 2 grounds. I tied the grounds together and ran to chasse, and tied the 2 blue/whites together and wired into the remote turn on on the head unit. I verified voltage going from the blue/white to the remote turn on on the head unit. Also on the amp piece of the harness are RCA plugs, which I ran into the head unit RCA out. (which one should it go to, front, rear, or subs? It doesn't seem to matter )
I think the amps just are not coming on, I don't hear a click....or there is an audio problem. I noticed one of the wires / solder points on the amp harness piece was broken. There are a total of 8 pins I think.... 2 blue/white for amp turn on, 2 grounds, white RCA, red RCA, and 2 other black ones I believe are ground for each RCA. One of those black ones was broeken, would that cause this?
Any help would really be appreciated, I really need to get this up and running. I'm new at car audio and really need some help bad
Old Mar 27, 2006 | 01:13 AM
joey_corleone82
Default RE: No audio from amps please help
well I was playing around trying things and all the sudden my key stopped working. I can't turn it either way I think it is a theft lock issue? Anybody know what is going on? My other key works still thank god. Also if I put the mach 460 head unit back in and connect the 2 harness wires and the antenna it will not come on at all
Old Mar 27, 2006 | 09:34 PM
joey_corleone82
Can anybody help with this? I have great sound from the 4 tweeters just can't seem to get the 4 subs to turn on. I'm really stuck at this point
JoshyGT
Sep 19, 2017 08:52 PM
breaking
Oct 2, 2015 01:27 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
