Shaker 500 Woofers
Old Apr 3, 2006 | 02:32 AM
Hoops_5_1's Avatar
Hoops_5_1
Default Shaker 500 Woofers
Does anybody have pictures of what the enclosure for the door woofers look like behind the 05 and 06 mustang door panels.
Check out my cars for sale:
https://mustangforums.com/m_1201822/tm.htm
Old Apr 3, 2006 | 11:29 AM
Philostang's Avatar
Philostang
Default RE: Shaker 500 Woofers
You know, I often feel like that dorky kid in the back of the classroom straining to raise his hand, "I know! I know...pick me!"
But I really do know this one.
The sub enclosure looks integral to the entire door panel. Some other guys here were saying that they modified it a bit for strength and to fit slightly deeper subs. It's all plastic, so anything is possible with some 4040.
[IMG]local://upfiles/28883/8A58C6DD73C84FC3A30BBAFF704E8CB3.jpg[/IMG]
Old Aug 25, 2006 | 05:42 PM
accidentaltribe's Avatar
accidentaltribe
Hey, I was wondering if you knew how DEEP the subwoofer case is on the door?? How deep of a Subwoofer could a guy put in without any modifications??? Thank you for your help...
Old Aug 26, 2006 | 08:50 PM
Stewart's Avatar
Stewart
It's really shallow. The stock sub is bolted to the enclosure in the center so it's raised where it bolts on.
Old Aug 27, 2006 | 02:07 PM
DaddyD's Avatar
DaddyD
You only have about 3.5 inches of depth. You also have to be carfeful of the width of the basket of the woofer. There is not much clearence on the sides either. I had a set of 3/4 inch MDF spacer rings made in order to mount Kicker 8" CVRs
Old Aug 29, 2006 | 07:18 PM
drtuba's Avatar
drtuba
DaddyD, which model kickers did you install. How would I go about getting spacers to get the kickers to fit. Also, did you replace the factory amps?
Old Aug 29, 2006 | 07:27 PM
drtuba's Avatar
drtuba
sorry bout the double post, not sure what happened here...
Old Aug 30, 2006 | 03:09 PM
DaddyD's Avatar
DaddyD
I used 8"CVRs, DVC, 2ohm
An audio shop made the 3/4" spacers for me out of MDF. It cost me about $25 for them.
You can cut them with a jigsaw, but I recommend a router, as the shop did for mine. The amps are factory.
They don't put out much in the way of power, but can handle pretty low impedence loads.
Old Sep 10, 2006 | 01:24 PM
PennState's Avatar
PennState
leave the orginial ones
and put two in the back
JoshyGT
Sep 19, 2017 08:52 PM
breaking
Oct 2, 2015 01:27 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
