Inside the 460's 6-CD changer...
Old Apr 11, 2006 | 10:38 AM
Smooth_J's Avatar
Smooth_J
Default Inside the 460's 6-CD changer...
I had issues with my 6-CD changer - wouldn't work - so I decided to just take it apart so I can try to fix it
I will not go into detail to remove the dash since there are many sites that cover this.
Just some words of wisdom:
-When taking off the middle dash there are two plastic clips on top of the vents, you would have to press them down in order to get the dash out
-I didn't have to take off my automatic shifter, but the more clearance... the better
-Disconnect both the + and the - battery terminals when doing this
-Make sure you have a medium sized flat head ready so you can pop out the connectors (fog, trac, etc)
-If you plan to take the CD player apart, make sure you had the unit off for at least 10 minutes or else it will be too hot to handle
-When taking the CDs out, watch out for the _tiny_ springs, or you will be there for quite a while putting everything back together :P
-While you have the CD player open, clean the lens, and etc
-As the sticker says on the CD player - do not drop it!
-When putting back in the car, make sure it goes back on the rails
-Try everything out before doing final hookup
-You will hear it go through the boot sequence (going through every disc) thats perfectally normal when reconnecting everything
-Enjoy!
Tools neded (for the most part):
- 9/64 wrench or ratchet - to take the CD6 out (will have to double check on that size)
- Philip screw sizes PH0, PH00, and PH000 (in some cases)
- Torx sizes T7, T9, T15 (could vary)
- Flat head scew driver
After all of this, it works!!! I probably will go aftermarket soon, but its good to fix things :P
This is the back of the front interface:
This is the inside of the CD housing (need to get my CDs out :P)
This is the radio and built in AMP:
This is behind the front panel:
This is the front interface:
This is the 6-CD housing - top view:
This is the 6-CD housing - bottom view (sorry if its not that clear):
This is the inside of the CD housing (with the CDs out):
This is how the top and bottom unit assemble together:
Old Apr 11, 2006 | 10:54 AM
bumperz's Avatar
bumperz
Default RE: Inside the 460's 6-CD changer...
Lovely rug!
Old Apr 11, 2006 | 11:54 AM
Danbert's Avatar
Danbert
I agree, that is stylin'
Old Apr 13, 2006 | 12:35 PM
03cobrafever's Avatar
03cobrafever
I ♥ Acer
hey man i got a used cd6 player that says slots are full but nothings in them ..something about regramming them ? i dont know what you think ?and hit the eject buttom nothing happens but radio works ..any ideas.? maybe there full but wont eject too.?
Old Apr 13, 2006 | 12:37 PM
Smooth_J's Avatar
Smooth_J
ORIGINAL: 03cobrafever
Is it under factory warranty still?
Old Apr 13, 2006 | 12:42 PM
03cobrafever
I ♥ Acer
no flood title ....changed all wiring
Old Apr 13, 2006 | 12:43 PM
03cobrafever
I ♥ Acer
i seen inetlizing or something on the face plate.
Old Apr 13, 2006 | 01:12 PM
Smooth_J's Avatar
Smooth_J
Do you hear anything happening inside mechanical wise?
Old Apr 13, 2006 | 02:24 PM
03cobrafever
I ♥ Acer
nay , i just to change to reg size cd radio ..what i need to fill that big *** hole in its place ..i can use the factory amps still with another radio right ?
Old Apr 13, 2006 | 04:36 PM
Smooth_J's Avatar
Smooth_J
Yes, but just like my last post says - you will get a popping noise everytime you turn it off or lower the vol to a min level. However I found a site in which seems to have found a workaround:
http://www.stangnet.com/Tech-Article...Head-Unit.html
