87 fox audio wiring
Old Apr 11, 2006 | 03:59 PM
Dearborn5.0's Avatar
Dearborn5.0
Default 87 fox audio wiring
I have an 87 GT conv with premium sound. I removed the factory amp which was grey and hexidonal on the floor under the dash. I removed the stock 4 connector
wire harness for the premium sound from the underdash wire harness. I plugged the 2 connector scoche (grey/black) kit in there. I have 2 wires remaining in the premium sound wire harness that feed the r/l door speakers. I cut those at a good length.
I have a 4 channel head unit I'm installing. Its a visteon dual media deck, tape and CD, stock in 2000 explorer. I plan to run 8 speakers. 2 IP, 2 door
on the front channel, and 2 rear pannel, 2 behind rear seat (not stock) on the rear channel.
I noticed that in the stock premium sound, the IP/Door speakers are wired from the same termimal, i.e. L-front & L door on one terminal, R front & R door on the other.
Can I do mine the same way?
I read about a bypass capacitor in the 1989 install post on 4/7/06. Should I do something like this as well?
Thank you
Old Apr 14, 2006 | 06:49 PM
Dearborn5.0
Default RE: 87 fox audio wiring
Old Apr 15, 2006 | 06:09 AM
ttocs's Avatar
ttocs
87's often used a common ground system which will not work with floating ground decks. You can trace the wires and seperate the grounds but running new wire to each speaker is often the best idea.
Old Apr 17, 2006 | 02:28 PM
Melectrok's Avatar
Melectrok
your hooking up 8 speakers. Are 4 of them tweeters, and if so you do you have the crossover boxes for them?
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
