fox wiring diagram (cd player install)
Old Apr 17, 2006 | 08:27 PM
elusive1's Avatar
elusive1
Default fox wiring diagram (cd player install)
anyone have the wiring diagram for the factory radio harness in an 87-93 stang? if it helps, i have a '92 in specific. thanks.
Old Apr 17, 2006 | 10:48 PM
elusive1's Avatar
elusive1
Default RE: fox wiring diagram (cd player install)
anyone? can anyone even tell me which wire is the power signal?
Old Apr 17, 2006 | 11:05 PM
Melectrok's Avatar
Melectrok
Im almost sure the yellow is the power and red is the ground
Old Apr 17, 2006 | 11:10 PM
elusive1's Avatar
elusive1
so yellow is the power... red is the ground.. and what about the battery (12v) signal?
Old Apr 18, 2006 | 01:45 AM
elusive1's Avatar
elusive1
bump.. anyone know for sure which is ACC power and which is battery?
Old Apr 18, 2006 | 05:21 AM
elusive1's Avatar
elusive1
or not
Old Apr 18, 2006 | 11:47 AM
Danbert's Avatar
Danbert
I am sorry I do not have an answer for you. I hope you are able to get an answer to your problem. If I knew, I would tell you.
Old Apr 18, 2006 | 01:23 PM
1fastzook's Avatar
1fastzook
You should go to your local auto parts store and get a computer safe test lite or if you have a dvm and test to see witch one is you acc wire/12v wire.
Old Apr 18, 2006 | 02:19 PM
Melectrok's Avatar
Melectrok
Try this site.
https://mustangforums.com/searchpro....mitbutton=+OK+
Can you say thank you?
Old Apr 18, 2006 | 08:30 PM
elusive1's Avatar
elusive1
yeah, thanks.
i saw that street dreams website page before, but wasn't sure if it would apply for a '92 considering it says 93-98 ford vehicles. but i guess it's probably still the same coloring..
