mach 460 questions
Old Apr 19, 2006 | 02:45 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Default mach 460 questions
how good is the mach 460 head unit (in dash 6 cd changer)? are there any specs available anywhere?
if I replace it with an aftermarket head unit and continue to use the mach 460 amps, will the sound quality increase at all?
also, what would sound better, using the mach 460 amps or running the speakers directly off the head unit amps?
is it possible to run all the speakers in the car directly from the head unit or do I absolutely need the external amps to power all the speakers in the car?
Old Apr 19, 2006 | 03:05 PM
Danbert's Avatar
Danbert
Default RE: mach 460 questions
I am not familiar with the Mach 460 system. But from what I have read, it isnt all that great if you are truly into SQ. Any change to it is an improvement. I have heard of so many problems with it that it would be best in my opinion to run the speakers off the head until you can replace them and get some amps. It really isnt all that difficult or expensive to upgrade from stock if you do soem research and are willing to take on the project yourself.
Old Apr 19, 2006 | 10:44 PM
ttocs's Avatar
ttocs
it is ok, of course there is always room for improvement. There is a hrns to integrate an aftermarket deck into it. It may help a little but unless you start adding additional amps you will not get better sound.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
