Replacing rear speakers in 94-98 convert
Old May 4, 2006 | 12:16 AM
CarlessAndy's Avatar
CarlessAndy
Default Replacing rear speakers in 94-98 convert
I was thinking about replacing the stock speakers in my 96 convertable. Has anyone taken apart the rear panels? If so how hard is it to do? and what sizes are the 2 in each side?
Old May 4, 2006 | 02:13 AM
ttocs's Avatar
ttocs
Default RE: Replacing rear speakers in 94-98 convert
it is soooooo much easier then the hard tops...
Start by removing the bottom section of the rear seat. There are two white tabs that are between where your legs would be if you were sitting it, wedged between the seat and the floor carpet. If you feel between the seat and floor you will feel them. push the center portion of the tab towards the back of the car, and then simply lift it up. There are some screws located below it. I am thinkin there was a plastic tab on the top of the panel that needed to be removed, as well as possibly another screw behind the wher the seat belt goes through the plastic, but it has been a while since I have done one....
importsmasher
Oct 9, 2015 04:42 PM
Tyoung68
Aug 25, 2015 04:31 AM
kdryan
Aug 21, 2015 04:01 PM
69FB
Aug 18, 2015 08:50 PM
Mustang Sally72
Aug 11, 2015 07:54 AM
