New rear deck speakers
Old May 19, 2006 | 09:16 AM
boostedgt02's Avatar
boostedgt02
Default New rear deck speakers
I went to put in some polk speakers in the rear deck and no sound what so ever. What can I do before i take them back to circuitcity? The only thing that I can think of is unplug both factory amps wire the new speaker to with the connector then hook back in the factory amps.
Old May 19, 2006 | 11:26 AM
ttocs's Avatar
ttocs
Default RE: New rear deck speakers
check fuses to see if the amp fuse could have blown.
Old May 19, 2006 | 11:33 AM
boostedgt02
Where would I check that on the factory mach 460 amps?
Old May 19, 2006 | 11:55 AM
Melectrok's Avatar
Melectrok
Hook the factory speakers back up. If they work the factory speakers are bad or incompatble, If they dont then you have issues beside the speakers.
Old May 19, 2006 | 12:20 PM
boostedgt02
I dont have the factory speakers anymore. I threw them out.
Old May 21, 2006 | 02:50 PM
ttocs's Avatar
ttocs
I would look for the fuses in the manual, I am sure they cover it in there. Check all the fuses as often there maybe a componant fused on a different circuit.
Old May 24, 2006 | 10:01 AM
boostedgt02
Well I dont have a manual for this but is there a fuse for the rear amps that would make the new speakers not work?
Old May 26, 2006 | 09:47 AM
boostedgt02
bump
Old May 26, 2006 | 11:47 AM
ttocs's Avatar
ttocs
it is possable. I don't remember what the impedence is for the factory rear speakers. If the impedence of the new speakers is lower then old ones the amp would run hotter and could have blown a fuse or just blown the amp.
I believe there is one fusebox under the drivers side dash, and another under the hood by the battery.
Old May 26, 2006 | 12:00 PM
Danbert's Avatar
Danbert
If you are unsure of your new speakers, find a home stereo to hook them too for a quick testing. I know they are different Ohms than home speakers but for a quick test just to see if they work, it wont make a difference.
