Upgrade Your Shaker
Old Jun 21, 2006 | 05:02 PM
  #21
praztek's Avatar
praztek
Default RE: Upgrade Your Shaker
05BlueGT,
Are you back in town, and if so.....shoot us some pics.
Thanks
Old Jun 23, 2006 | 01:23 PM
  #22
praztek's Avatar
praztek
Anyone?
Old Jun 23, 2006 | 09:18 PM
  #23
Red_Stallion's Avatar
Red_Stallion
ORIGINAL: praztek
Anyone?
Pretty please, I've been waiting very patiently
Old Jul 8, 2006 | 02:42 AM
  #24
praztek's Avatar
praztek
Ok, currently installing a new HU, have a question. The two connections to the left of the pic, what are they for, because they won't be connected to the new HU?
Thanks
[IMG]local://upfiles/24825/F6F923816AFC4D71B76A42B2E957C539.jpg[/IMG]
Old Jul 8, 2006 | 07:18 AM
  #25
ANBAUTO's Avatar
ANBAUTO
I dont know what they are but i installed the Alpine IVA-W200 in mine without those and i did get the plug and play harness to make it all nice and easy
Old Jul 8, 2006 | 01:22 PM
  #26
praztek's Avatar
praztek
I'm being told the one to the lower left is for the subs, and the next one is the cd changer which we no longer need. If you didn't plug into the one furthers to the left to the new hu, then was there front l/r sub connection wires on the new harness?
Old Jul 8, 2006 | 04:31 PM
  #27
praztek's Avatar
praztek
Ok, heres the plan. Take a pair of rca's strip on side-->tap into the connection that I un plugged from the rear of the shaker "sub woofer connection"-->run the other side of the rca's to the front amp output on the rear of the new hu. Now with that being said, anyone know the wire config on that connection?
Thanks
Old Jul 8, 2006 | 05:05 PM
  #28
praztek's Avatar
praztek
See pic.
Left to Right
Brown/Orange
Pink/Brown
Blue/Purple
And of course the Ground
Just was wondering about the top three, prior to finishing up the install. Per stripping the one end of the rca's, can I ground the negative portion of both sides "right/left" to the conectors negative in the pic?
Thanks
[IMG]local://upfiles/24825/F9E898B8A35C438EAAAD7E7559A4F8F4.jpg[/IMG]
Found this after posting: http://www.allfordmustangs.com/forum...achmentid=8318
Old Jul 8, 2006 | 11:03 PM
  #29
praztek's Avatar
praztek
I've read that the blue/purple is the remote turn on and the others are for the subs. Any issues with connecting the speaker ones up to rca's and going right into the new hu rca front inputs? I was also going to put a 4.7 resistor on the radios remote turn on wire to eliminate the popping sound when turned on. Can I just soldier it between the remote turn on wire?
Is Amp turn on, Remote turn on and 12 v ignition switched one in the same?
That is the correct Metra part # for the 06 Mustang, think I'm hanging this project up for a bit and ordering one.
http://www.audiooutfitter.com/store/70-5521.html
Thanks
Old Jul 9, 2006 | 05:02 AM
  #30
ANBAUTO's Avatar
ANBAUTO
damn thats some good info im going to need to hook mine up as well. maybe ill order that connector.
