12" sub?
Old Jul 14, 2006 | 06:54 PM
grabbem88's Avatar
grabbem88
Default RE: 12" sub?
http://stores.ebay.com/Trading-Circuit
Old Jul 14, 2006 | 09:09 PM
Hoops_5_1's Avatar
Hoops_5_1
I'm having a custom made fiberglass box that will fit two 12" subs in the back corners of the trunk in my 06 GT. Should have some pictures by next week some time, also made some custom door pod speakers to go where the 8" sub would go if i had the shaker 500 package.
Old Jul 15, 2006 | 03:50 PM
nanaki's Avatar
nanaki
Retired MF Moderator
ok. change of plans. i'm gonna get a single 10". now to find something at least 1600watt to take advantage of that amp i have. i found this but i'm warry on cheap subs.
Old Jul 15, 2006 | 11:15 PM
Action_Jackson's Avatar
Action_Jackson
If you get a 12" sub and use a sealed box they usually only need around 1 cubic foot of airs space, if you use a ported box it will need around 1.7 cubic feet. With a ported box you will get more decibals and with a sealed box you get more sound quality. Crutchfield hase a mtx 10" woofer with an enclosure designed for the 04 mustang, but they are not all that hard to build and any audio shop should be able to build you one for around $70 or so. Alot of those cheap speakers that are rated at like 1800w are full of crap. I wouldn't trust them. I have an Infinity Kappa Perfect sub, purchased for around $250. It is rated at 350w rms and 1400w peak, you have to check your amp also because the 1600w may be overated or just the peak output, what you are looking for is the rms output with a low distortion. If you put too much power to your speakers with distortion, the voice coil will overheat and blow your speaker.
Old Jul 16, 2006 | 02:11 AM
nanaki's Avatar
nanaki
ok. my amp actually blew today (it's a sign. i NEED a new sub now). i'm gonna use that 1600watt amp i have and was think either this one:
https://www.ikesound.com/product-product_id/3108
or this one
https://www.ikesound.com/product-product_id/3502
i was gonna get 2 800watt peak pioneers for $50/ea and get a new box, but then i saw the alpine. THEN i saw the pioneer. you guys think i should get that pioneer or alpine?
also, you think those things will put a lot of strain on my battery and/or alternator?
Old Jul 16, 2006 | 02:20 AM
grabbem88's Avatar
grabbem88
mine does...when i thimp my ol' JL 03 12"
Old Jul 16, 2006 | 02:33 AM
nanaki's Avatar
nanaki
your car needs a new alternator?
Old Jul 16, 2006 | 03:35 AM
grabbem88's Avatar
grabbem88
no it get's drained pretty good....powermaster 160 amper...but i think i have a draw in my headlights[&:]
Old Jul 16, 2006 | 06:26 AM
cryptic26djp's Avatar
cryptic26djp
What amp do you have?
Personally, I would recommend nothing less than Kicker or JL Audio! If you have the power, you will be COMPLETELY satisfied! Dont waste your money on cheap subs, NEVER EVER!!!!
Old Jul 16, 2006 | 07:41 PM
TopNoTcH5.0's Avatar
TopNoTcH5.0
i have two 15" kickers in the back of my 90 5.0 with a 2000 watt amp heres a pic
http://i62.photobucket.com/albums/h1...2wpgiWUpPK.jpg
