where to hook up remote wire
Old Jul 16, 2006 | 09:07 PM
NickiStang04's Avatar
NickiStang04
Default where to hook up remote wire
hello all
I Searched but didnt get the answer i needed.
I am putting an aftermarket amp and sub in my mustang. Still using factory cd player. where do i put the remote wire so my amp will turn on???
TIA
Old Jul 17, 2006 | 11:01 PM
Blueper's Avatar
Blueper
Default RE: where to hook up remote wire
Hook up a switch.
Flip it on when you want to BOOM.
Old Jul 18, 2006 | 07:58 AM
stangcrazy's Avatar
stangcrazy
Did this in my daily driver. I hooked it up to the Ignition wire for the radio just spliced it into the factory cable. I am going to install a switch here in a lil while so I can turn it off when kids are in the car with me.
Old Jul 19, 2006 | 01:48 PM
Brute03's Avatar
Brute03
if i remember right there's a blue wire behind the H/U that you can use as the turn on lead , just use a tester to make sure
Old Jul 19, 2006 | 02:23 PM
stangcrazy's Avatar
stangcrazy
That is usually the case on an aftermarket HU but as for a factory HU you will have to splice into the ignition wire.
Old Jul 21, 2006 | 03:35 PM
NickiStang04
ok , i hooked into the fuse that operates when key is turned on. Amp powers up, but no sound from any speaker. if i unplug my speaker input from amp and plug it back in , the speakers and sub come on. but if i turn car off and turn back on, have to repeat,unplug plug back in....???????
any suggetions?
Old Jul 21, 2006 | 03:37 PM
98GTpony's Avatar
98GTpony
GET A SWITCH...
Old Jul 21, 2006 | 03:41 PM
stangcrazy's Avatar
stangcrazy
Well the bold font got my attention but unfortunatly i don't know what to tell you. I had a problem with mine when i hooked it up to factory HU the first time i turned it on just had a steady tone on it but i pulled the sensor cable and put it back on and it works fine.....................as far as inputs on my set up i spliced a set of RCA's into my rear speaker wires. How do you have your input to the amp set up?
Old Jul 21, 2006 | 03:50 PM
98GTpony's Avatar
98GTpony
you need something like this
http://www.radioshack.com/product/in...entPage=search
Old Jul 21, 2006 | 04:07 PM
NickiStang04
WOW!!!! that was some BOLD font
lmao! had a blonde moment
