Mach 460 issues, help please!!!!!!!
Old Aug 3, 2006 | 02:47 AM
Anthonyandmarisol's Avatar
Anthonyandmarisol
Default Mach 460 issues, help please!!!!!!!
I have a 1998 gt mustang, and i have the Mach 460 stereo system in it, i bought the wiring harness and hooked it up, i unpluged the black harness inside the dash and pluged it into the harness that i bought and i took the stock harness that comes out of the stock head unit and put it into the new harness that i bought, it works fine but the 2 lower speakers in the front and back DONT WORK!!! so only the highs are working please help your fellow mustang owner out
Old Aug 3, 2006 | 03:03 AM
ttocs's Avatar
ttocs
Default RE: Mach 460 issues, help please!!!!!!!
You need to get a signal to the subs by way of the small black square hrns that was plugged into the back of the deck. I used the subwoofer RCA out on my alpine and use a line driver to boost the signal up to where the factory jbl amp is used to getting. If you don't have the sub out on the deck you can use the speaker out on the deck. With the rca sub out you get a little more adjustability of the sub.
Check page 2 in my signature.
Old Aug 3, 2006 | 03:26 AM
Anthonyandmarisol
ORIGINAL: ttocs
Thanks Alot, but which black harness that comes out of the stock head unti there were 2 that were pluged in there were 2 small black ones one was slightly bigger than the other the bigger one has 8 pins in it and the smaller harness has 6 please let me know which one thanks and when i do find the right harness cant i use a line out converter? o
Old Aug 3, 2006 | 12:35 PM
ttocs's Avatar
ttocs
the small one with 8 pins. You can use a LOC off of the amplified speaker level outputs, but there is a chance that it will be too weak of a signal for the factory amp. If that is the case then you can use the speaker wires.
Old Aug 4, 2006 | 06:24 PM
Anthonyandmarisol
hey man it didnt work i used that lil 8 pin square harness and it didnt work i didnt use a Line out converter but i cut the wires and tried to hook it up but its not working no sounds help me out please what is a mustang without the mach 460 lol plz help
ORIGINAL: ttocs
Old Aug 5, 2006 | 11:57 AM
ttocs's Avatar
ttocs
did you also connect the blue remote turn on?
Old Aug 5, 2006 | 02:54 PM
Anthonyandmarisol
No wheres that?
ORIGINAL: ttocs
Old Aug 5, 2006 | 06:24 PM
ttocs's Avatar
ttocs
there should be a blue wire on the back of the deck and on the power hrns. It tells the amp to turn on.
Old Aug 5, 2006 | 09:23 PM
Anthonyandmarisol
yeah man that was the problem thanks a bunch, i dont care what anybody says your the stereo guru the best stereo **** on here thanks a lot man
ORIGINAL: ttocs
Old Aug 6, 2006 | 01:24 AM
ttocs's Avatar
ttocs
thankyou and yer welcome.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
PaulH2
20
Jan 31, 2016 09:48 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
