amp question
Old Sep 4, 2006 | 09:31 PM
chrisfnmac911's Avatar
chrisfnmac911
Default amp question
is there any way to wire two amps up to one sub? i have two kenwood 800 watt amps and a kicker l5 sub, thanks
Old Sep 5, 2006 | 03:54 AM
Choppa's Avatar
Choppa
Default RE: amp question
you could do that but how many watts is the sub? if the amps total more then the sub then dont that equals a blown sub you want the amp(s) to be less then the sub 100 watts less is fine that way you have no worry bout blowing the sub. whats yous sub and amp combo?
Old Sep 5, 2006 | 12:16 PM
1fastzook's Avatar
1fastzook
Yes you can hook 2 amps to 1 sub as long as the subs a DVC.You will have to have the gain on the amps set correctly/even or you will damage the sub.You can run more power then the sub says it can handle aslong as it clean power
Old Sep 6, 2006 | 07:43 PM
chrisfnmac911
it is not a DVC, thanks for your help
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
