Old Oct 20, 2015, 11:05 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
How do I get car into keyless remote program mode?
Old Sep 5, 2006 | 06:18 PM
gentlejax2's Avatar
gentlejax2
Default How do I get car into keyless remote program mode?
I got a new remote and need to program it for my 94 Cobra
Mike
Old Sep 18, 2006 | 08:17 PM
ret27m's Avatar
ret27m
Default RE: How do I get car into keyless remote program mode?
How to Program a 1994 Mustang GT Ford Remote
To program (or reprogram) keyless entry remote transmitter into the remote
keyless entry module, perform the following steps:
1. Turn ignition switch to RUN or ACC position and momentarily short the
two terminals of the Program Connector (two-pin connector next to the remote
keyless entry module. Remove LH luggage compartment trim panel (Trunk Area) to reach the
connector). Both doors should lock and then unlock. Remove shorting pin.
2. Press any button on keyless entry remote transmitter. All front doors
should lock and then unlock to verify that keyless entry remote transmitter has
been programmed.
3. If door locks do not respond, press button again (up to three times
maximum with the same keyless entry remote transmitter).
4. Repeat Step 2 to program additional keyless entry remote transmitters (up to 4 remotes)
into the remote keyless entry module (up to a maximum of four keyless entry
remote transmitters).
5. Turn ignition switch OFF. Both doors should lock and then unlock.
6. Check operation.
The above is for the 94-98 Ford Mustang, other years should be the same.
Old Sep 19, 2006 | 09:10 AM
Blueper's Avatar
Blueper
ORIGINAL: ret27m
been programmed.
6. Check operation.
+1
It's in your manual.
Old Jul 3, 2007 | 09:13 PM
Redstang55's Avatar
Redstang55
Thanks...I was just aboutto ask the same question.
Where exactly in the trunk area is the in the LH luggage compartment trim pane?
thanks a bunch
djbigskrilla
Sep 20, 2022 01:04 AM
MusBBad95
Aug 17, 2015 09:39 PM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
