Prolbem with HIDs
Old Sep 7, 2006 | 05:18 AM
warstory26's Avatar
warstory26
Default Prolbem with HIDs
ok my dawm HIDs keep turning off at times sometimes its the left one then the right one sometimes they just flicker on and off. Any body have any ideas my shops says its the ballist and they guy I bought it from says it the install.......someone please help
Old Sep 8, 2006 | 12:16 AM
schapman's Avatar
schapman
Default RE: Prolbem with HIDs
sounds like the ballast. Did you change the headlight fuse when you installed the HIDs? you may need to increase the fuse to 25 amp.
Old Sep 16, 2006 | 02:29 AM
Saleen05797's Avatar
Saleen05797
Hey
I have this same problem. Did you ever figure out a fix?
Thanks!
Old Sep 16, 2006 | 10:42 AM
ttocs's Avatar
ttocs
often it is the ballast. check the connections as well.
Old Sep 16, 2006 | 02:09 PM
laserred38's Avatar
laserred38
i just bought some HIDs and on some sites it says you have to upgrade the fuse as already stated...i think i will just do it to be on the safe side as i have a 2 amp stereo system and my heaglights already dim a little bit when i crank on it
Old Sep 16, 2006 | 07:01 PM
ttocs's Avatar
ttocs
another thought I had was that HID's are current driven. If you have underdrive pulleys and maybe have low rpm's when taking off, you may not supply the voltage/current needed to strike the HID light.
Diode Dynamics
28
May 26, 2022 12:02 PM
kawiguy827
Sep 22, 2015 10:52 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
inyadreems
Aug 21, 2015 09:10 AM
notsoswwuyd
Dec 24, 2004 01:13 PM
