Ground Wires..
Old Sep 10, 2006 | 02:12 PM
Verado's Avatar
Verado
Default Ground Wires..
Im having a problem with my Mach460 on my 2000 Stang. Im thinking its the ground wires because the radio does an annoying pop when it turns off and off. Does anyone know where they are?
Old Sep 11, 2006 | 11:19 AM
ttocs's Avatar
ttocs
Default RE: Ground Wires..
the amps are in the back below the package shelf. If you replaced the factory HU then you may need to put a resistor in the remote turn on wire.
Old Sep 11, 2006 | 12:46 PM
schaedj's Avatar
schaedj
Would this be the same thing that causes a Shriek? When I power on the head unit (Pioneer "Premier") in my car, it makes a horrible shrieking sound. After that everything is OK.
Old Sep 11, 2006 | 06:30 PM
Verado's Avatar
Verado
ORIGINAL: ttocs
I replacd the amps and the head unit and it still does that.
Where does the resistor go, were and which wire?
Thanks.
Old Sep 12, 2006 | 09:57 AM
ttocs's Avatar
ttocs
ORIGINAL: schaedj
it could be. Do you have your deck powering the factory subs as well? How do they sound?
Old Sep 12, 2006 | 09:58 AM
ttocs's Avatar
ttocs
you wire it in series, on the remote turn on wire.
ORIGINAL: Verado
ORIGINAL: ttocs
Thanks.
Old Sep 12, 2006 | 02:37 PM
schaedj's Avatar
schaedj
Yes, the deck (Pioneer DEH-P930) is powering the subs. There is no additional amp in the system. They sound fine. Nice and loud. The only (major) issue with the deck is that shriek.
I've got to pull the whole thing out anyway, there's a wiring problem with the changer (Pioneer CDX-PD6) giving me an error 55 on the head unit. I pulled the changer out last night and saw sparks coming from the wiring harness underneath. YIKES! probably the wires aren't properly taped / wrapped, but that scares me. I'm planning on redoing the whole thing to get it right.
Now all I have to do is figure out which one is the remote turn on wire...
Old Sep 13, 2006 | 11:12 AM
ttocs's Avatar
ttocs
blue
Old Sep 18, 2006 | 02:12 PM
schaedj's Avatar
schaedj
Thanks a million. I pulled the radio and the wiring harness this weekend. I resoldered all of the connections, eliminated any bad splices and crimp connects, and soldered in a resistor (1KOhm) across the Orange, Red and Blue wires. The red and orange wires already had resistors across the wires from the factory harness. I plugged everything back in, and the Shriek was gone. The sound system sounds awesome now, crystal clear and no pops, sputters or shrieks.
Thanks for all of your help,
Dave
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
Mr. D
Suspension
Sep 20, 2015 09:20 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
