Good or Bad Amp
Old Oct 5, 2006 | 01:07 AM
Supercharger_Man_85's Avatar
Supercharger_Man_85
Default Good or Bad Amp
I was messin around on ebay when i found a 2000 watt (peak) amp for 18 bucks with 8 min left i couldnt believe it so i looked at it quick (not much time left on it) its a mitzu audio 2000 watt amp new in box so i end up winning it pay $44.74 after shipping i just bought it and now am wondering if its a good amp anyone here no anything about this amp or company. Anything would be appreciated!!!
Old Oct 5, 2006 | 01:09 AM
Supercharger_Man_85
Default RE: Good or Bad Amp
Here is a pic of the amp>
[IMG]local://upfiles/39733/C536CCAAE57049B6AFEF8649B97F10DA.jpg[/IMG]
Old Oct 5, 2006 | 11:47 AM
ttocs's Avatar
ttocs
uhm, ya get what ya pay for?
When you get the amp take a look at the fuse on the side, it is probably a small one showing that the amps true output is much lower then 2kwatts.
Old Oct 5, 2006 | 12:17 PM
P Zero's Avatar
P Zero
What you need to look at when buying a car audio amp (or any amp for that matter), is the THD (total harmonic distortion). That is what truly indicates the quality of an amp. Good amps will have something like .01%, an acceptable amount is .05%. Anything over that itll sound like poop. Also, the true RMS (root mean square) output is the TRUE wattage output of the amp. Peak wattage means nothing.
-P.
Old Oct 5, 2006 | 09:37 PM
ttocs's Avatar
ttocs
on top of that you also need ot make sure that the specs of the amp are measured with the standard SEMA variables. Amps like this advertise 2000 watts when it could be closer to 200...
Old Oct 29, 2006 | 02:08 AM
11secfox's Avatar
11secfox
common rule is $1 per watt or so
Old Oct 30, 2006 | 09:31 PM
00raging stang's Avatar
00raging stang
that amp is prolly garbage
Insidian
Carolina Regional Chapter
Sep 8, 2015 05:33 AM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
