Popping after Shaker1000 replaced
Old Oct 13, 2006 | 11:47 PM
flapjack's Avatar
flapjack
I ♥ Acer
Default Popping after Shaker1000 replaced
This is a long going problem with some recent progress.... please read.
Dmhines really helped me out with the initial "POP!" I got when turning on my car. It was due to the new aftermarket headunit sending 12v to turn on the factor Shaker1000 amp. He told me how to install a +5v regulator from Radio Shack to eliminate the problem.
I installed the regular on the metal framework surrounding the radio behind the dash with a machine screw and lock washer. I found a good ground for the regulator and wired up the +5v remote wire from the headunit.
Now when I turn on the car, the initial pop is gone. However, I get popping while music is playing. It's only on bassy notes when the volume is up more than halfway. I actually had to go in and turn off Loudness and turn the bass way down. Even so, it still does it if I have it too loud.
It never did this until after I installed the +5v regulator. Before installing the +5v regulator, I only got the pop when the headunit turned on.
I really want to get this fixed. It's driving me absolutely crazy. The headunit is a Premier 9800.
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
cbird1177711
Sep 3, 2015 08:43 PM
