sound system question
Old Oct 14, 2006 | 04:23 PM
silverstang1996's Avatar
silverstang1996
Default sound system question
alright well last night i was driving down the road and then i switched to the next song on my CD and for some reason my sub woofers just cut out? so when i got home i checked all the wires i could with the exception of the ground wire and the REM wire(i think thats what its called) because i had everything professionally installed and dont wanna go ripping anything apart..any help?
thanks
Old Oct 17, 2006 | 06:32 PM
ttocs's Avatar
ttocs
Default RE: sound system question
if you had it proffesionally installed then take it back before you rip into anything. Isntallers do not like you digging in their work and then comming back. Is the amp on?
Old Oct 17, 2006 | 08:25 PM
Meph's Avatar
Meph
Check your fuse.
Still good or blown?
Old Oct 20, 2006 | 02:49 PM
00raging stang's Avatar
00raging stang
something probably just came disconnected
Old Oct 20, 2006 | 04:13 PM
laserred38's Avatar
laserred38
amp may have overheated...what kind do you have?...i know in my old Contour i had some POS sony 10" subs and a POS sony amp...it was a 2 channel 90x2...for those subs it was fine...but when i hooked up my friend's JL 12s....it would cut out because the JLs were sucking the power out of the amp...it would get REALLY hot and the amp would go into protection mode to protect it from being damaged internally...also check the fuse(s) on the amp
Granatelli Sales
Jan 20, 2020 12:34 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
Sep 1, 2015 08:16 PM
