Is it possible?
Old Nov 6, 2006 | 06:14 PM
c03bra's Avatar
c03bra
Default Is it possible?
I have an '03 cobra with the mach system. is it possible to hook up one of the in-dash double din dvd units without having to lose the mach system? any recommendations on units, as well as any place for instructions on bypassing parking brake limitation?
thanks.
Old Nov 6, 2006 | 11:59 PM
seight311's Avatar
seight311
Default RE: Is it possible?
Double din fits perfect in the 00 and up stangs. Eclipse head units are superior performance and quality. The AVN6600 is insane but may have more features than you really need. Yes theres a wiring harness you can use to basically not use your speaker wire outputs just so long as the head unit your putting in has front rear and if your running them non-fader (subwoofer) outputs. Look at metra for your kit and harness the 70-5510 is the one i used to integrate to my mach system, im pretty sure its the exact same for the 03's but i cant confirm that. The parking brake theres 2 real options. plug it in and stay 100% legal, because it operates to the e-brake light not the brake itself "braking" the car. So if you hook it up and just put your e-brake on 1 click you can use the video on the unit and not worry about a cop testing it and writing you a ticket for it. Or yes you can simply run the wire that is labeled to run to the e-brake to a ground and viola it thinks the ebrake is on all the time.
