head unit
Old Nov 4, 2006 | 10:25 PM
stang91's Avatar
stang91
Default head unit
guys Im new at so I was wondiring if I can get some help I got a new head unit for my 91GT stang and I got the harmness for the year of my car did every thing wire by wire when it was time to plug the head unit it turn on but I didnt get any soud from speakers so I check some of the threads here and I saw the bypassing some factory amp or something can someone help and how do you do this thanks so much[sm=dontgetit.gif]
Old Nov 5, 2006 | 05:34 PM
Xeremeh's Avatar
Xeremeh
Default RE: head unit
I had the same problem with my old F-150. Ford decided to add amps into different years to **** with your head, and wiring harnessess won't include them. I basically took back the harness, then just spent 3 hours trial-and-erroring all the wiring connectors. Good luck!
Old Nov 5, 2006 | 05:58 PM
ttocs's Avatar
ttocs
check to see if you have the remote turn on from the deck wired into the amp turn on for the car. It does sound better if you bypass the amp(large octagonal piece of metal with a bunch of holes in it in the bottom center of your dash) but if you do not know what hrns to look for it can be hard to find. Try tracing the wires that come out of the amp and one hrns should go behind the golve box and have a hrns with 8 wires on it, that goes to the speakers and bypasses the amp.
Old Nov 5, 2006 | 07:57 PM
stang91's Avatar
stang91
I got it I did that and works fine thanks
Old Nov 7, 2006 | 12:08 AM
seight311's Avatar
seight311
Seen alot of kids come in with their SN95s and they simply forgot to connect the power antenna wire or illumination wire i cant think of which right off the top of my head but I had people returning cd players because of this issue and it got old and they refused to pay for it to be installed so i eventually had to start going out and hooking it up for them to stop them from returning the cd itself. Kinda sucked for me as far as making more money but, better than losing it all you know.
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
